Question about Braun Flex Integral 6520 Electric Shaver
The on/off mechanism on my dads braun 6520 is stuck. It won't turn on.
    President:
  • 704 Answers
Hello running girl, Have you looked to see if maybe the "lock-off" feature hasn't been engaged?
If you look at the razor, right above the on/off and sideburn trimmer selector, you should see a full bar that goes all the way across the shaver. Push this up toward the shaving head to unlock the razor and the shaver should work fine again.
This is a Braun design feature there to help prevent the shaver from accidently getting turned on when packed in your luggage, etc. and running down a fully charged shaver.
There is nothing like reaching for what you thought was a charged and ready to use shaver and discovering that it got switched on and ran the batteries down.
Other than having the lock off feature engaged, I can't think of anything that would cause the switch not to turn on, unless the shaver was dropped and damaged. If that's the case, you will want to have it looked at to make sure the printed circuit board hasn't been broken, etc.
Typically this isn't something that most folks can undertake a diagnois and repair, so I'd suggest you contact www.electricshaver.com or call them at 1-888-476-1785 to get an estimate for repairing it.
Hope you find this Very Helpful and best regards!
Posted on Oct 10, 2009
Where can i take my Braun 6520 to have the battery replaced?
If your shaver works but will not longer hold a charge as long as it should, the batteries need to be replaced. If the shaver is dead and the green indicator no longer illuminates when plugged in, you have waited too long and the circuit board is now damaged and can not be repaired.
For battery replacement, see shaveroutlet.com at the link below
Professional Battery Replacement for Most Models
Dec 28, 2016 | Braun Health & Beauty
I have 6520. when i plug it into a wall jack i does not charge and does not show power from the wall jack any more. this means when the battery is out it will not work any more. please help
Model 6520: If the green light no longer illuminates when you plug it in, you have waited too long to address the battery problem and the circuit board is now damaged. Replacing the batteries alone will not help as it will still not be able to recharge. To repair, you will need a new circuit board but Braun has discontinued for this model. You will be lucky to find one at this date.
model 5520, 5525, 5550, 6520, 6525 and 6550 are all prone to this problem when you neglect batteries that no longer charge correctly. It is suggested that batteries be changed early on when you notice that they are a problem instead of running your shaver from the cord until it dies.
Aug 12, 2011 | Braun Health & Beauty
Shaver stopped working today--no green light or movements even when connected to cord battery has not been holding charge the past year for repairs--how to ship and do you give estimates before...
Here is an equivalent circuit diagram good enough to repair the circuit board - What I have found is that the batteries go bad, draw too much current and blow the fuse or in the case of mine, over current the transistors. Resistors are in ohms
' ' o
' Unknown ' '
' __ ' '
' -o' 'o- ' '
' -o' 'o- ' ' ST Micro
' -o' 'o- ' ' STD616A
' -o'__'o- ' '/
' -o' 'o-----' .-----------'
' -o' 'o- ' '>
' -o' 'o- ___ '/ NXP '
' -o'__'o--'___'------' BF820215 ' '
' 330 '> '---------''- --
' ___ ' 1.2V
'-------------'___'--------'
1.3K
750ma Pico Fuse
.-----. _
-'~ +' ----o_/ \o-----
DF08 Full Wave Bridge
Nov 30, 2010 | Braun Flex Integral 6520 Electric Shaver
Battery is fine - but green light showing recharge is no longer lighting and no electricity is getting to battery. It has NEVER been dropped or mishandled. Shaves fine but only on minimal battery power...
Assuming that your cord is not damaged, the circuit board is bad. This most often happens when you continue to use the shaver well after the batteries have lost their ability to hold a charge well.
You will find a new circuit board for model 6520 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-106.html
Apr 01, 2010 | Braun Flex Integral 6520 Electric Shaver
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
Braun 6512 shaver stop working
hi i would say that you have major problem with this did you drop it sounds like a problem with the circuit contact braun or shavers uk kevin.
Oct 30, 2007 | Braun Flex Integral 6520 Electric Shaver
Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Jun 10, 2007 | Braun Flex Integral 6520 Electric Shaver
No power
The motor brushes may be bad. Take the screen off and turn the shaver on. Manually move the blade back and forth a bit and see if it starts to engage. If it begins to run when you do this, the brushes are worn. Braun does not make replacement motors for your shaver
Jul 11, 2017 | Braun Flex Integral 6520 Electric Shaver
Braun Flex Integral 6520 Electric Shaver Logo
284 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
