Question about Gateway MX6447 Notebook
No power my laptop is not taking a charge, the light doesnt light up when you plug it in
  • Diablo Ro Jun 28, 2008
    I have to push adapter in to get it to charge. Otherwise it won't charge at all.
I have 4 x gateway laptops all with the same fault.
They all work fine from battery but will not charge.
This is a common fault with them, I have been trying to get a copy of the motherboard wiring / circuit diagram.
Also I have traced the fault to possibly 6 components.
will post again with more info when available
Posted on Oct 01, 2008
    Problem Solver:
  • 11 Answers
First remove your battery and insert the charger directly to the notebook and try to switch on,thus your battery is not in used.If the problem continue then there is problem with the botton switch or motherboard.
Posted on Dec 23, 2007
My gateway nv79c54u laptop ac plug doesnt charge just blinks orange
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 12, 2012 | Acer Gateway NV79C54u 17.3-Inch Laptop...
Gateway laptop died. Several times it appeared to reboot only to go black and go off. No fan or lights. How can I fix this myself?
does it show that it is charging from the charging light/power supply? Is there any life left in the battery? is the charger charging the battery? the batteries dont last in laptops usually about a year before the go bad and have to be replaced, Is the charger working? The chargers go faulty all the time, The little plug that plugs into the laptop goes faulty and is a very common fault and doesnt charge/power the laptop, The only thing you can try is another power supply of the same name/model/output voltage and current with the same small plug and polarity or another battery of the same type/model, If you can do this and it doesnt cure your fault it needs looked at by a technician, Hope this helps, If you need more assistance let me know,
Sep 19, 2011 | Gateway Computers & Internet
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
Fujitsu Siemens AMILO Pro V2030 Not Boot, power button doesnt do anything. Only charging light is on when plugged to power. What should be done?
You have a problem on the motherboard.The power regulator circuitry in laptops is on the motherboard. You'll need to take it to a repair shop.
Apr 04, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have an everex nc1500. it was on working fine, then it suddenly went dead like it was on battery,(but was on charger). now no lights come on ,it doesnt charge, doesnt try to turn on in any way. it acts...
This seems like a poor soldering job at the factory which has become loose/disconnected over time, affecting the power port the ac adapter plugs into. Take the laptop to the shop and have your power jack inspected.
Mar 10, 2011 | Everex StepNote NC1500 Notebook
When I plug the AC plug into my computer, the battery light doesn't appear that it's charging. I purchased a new battery and still doesnt charge. any ideas?
try to darin the batter first. heres the procedure. take out the battery and unplugged the power adapter. press and hold the power button for 30secs. after 30 sces, put the battery and adapter back in. then power on the computer and observe.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Cannot power on, even when plugin the AC there's no lights (no charging)
Hello
This is a power problem.
First remove try charging your laptop with another power cord to see if it works
If it doesnt,remove the battery from the laptop and plug the laptop directly into power if the laptop comes on,then the battery is faulty and you should get a new one
But if it doesnt then the charging port is no longer working and you should get a repairer to help you change the charging port
Thank you for visiting fixya
Mar 06, 2010 | Gateway MT6707 Notebook PC
My acer doesnt power on at all i plugged it in to the charger and it wont charge power light doesnt even light up and i plugged it in with no battery and still nothing. any ideas on whats wrong with it?...
Check it by putting it on another Power Adapter. It sounds to me as if the Power Supply has failed... Thats the bit that supplies DC.. to the laptop, and charges the battery, they fail frequently. Take it to a PC store and ask them to test it with another supply. The Power Supply MUST be the same specs tho.
Jan 19, 2010 | Acer Extensa Laptop
The power button doesnt start the laptop
Toshiba Satellite R15-S822 Tablet: Battery is charged and operational power supply (charging light is on) is plugged into power port on back side of laptop: Problem is sliding "power on" switch does not start laptop - no sign of any electrical activity...
Nov 04, 2009 | Toshiba Satellite R15-S822 Tablet PC
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Gateway MX6447 Notebook Logo
186 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
