Question about Polycom Vortex EF2280 (220012280001)
I am looking for and explaination on erro code on and ASPI system error code 272 on an EF2201 errpr code 291 on a 2280
MY PS3 HAS STOPPED PLAYING GAMES NOW I TRY TO LOAD A GAME THIS ERROE COMES UP 80010514
Either a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware.
These are both serious issues that are permanent. A factory reset may help but is unlikely.
http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/
Sep 10, 2010 | Computers & Internet
Erroe message on screen "system error contact xbox support
Is there an error code on the bottom of the screen?
E73?
E74?
E68?
E69?
Or another code?
May 28, 2010 | Microsoft Xbox Console
Vaio cr363 dvd writimg problem.
Installing a working ASPI layer
For years people have had various problems with the so called ASPI layer, which is required by many Windows CD-R software’s. This article aims to successfully install a good and working ASPI setup.
What is ASPI?
aspicheck.gifThe term "ASPI" stands for Advanced SCSI Programming Interface. It’s a universal driver layer that operates in between software and the CD-R hardware. It is often referred as 'ASPI layer', ‘ASPI driver’, 'ASPI Interface', which are all synonymous terms for the same thing. Windows 95/98/ME ships with a poorly implemented ASPI layer, while NT/2000/XP has no ASPI layer built in. You can check your current ASPI setup by using the ASPICHK tool that comes with the Adaptec ASPI distribution.
Many software titles install their own drivers to the operating system and therefore do not need an ASPI layer. Such software titles include CloneCD, DiscJugger, GEAR, BlindWrite and many others. On the other hand there is a large number of software that require an ASPI driver installed: Exact Audio Copy, Feurio!, BurnAtOnce, CD-R Indetifier, and so on. Nero Burning ROM comes with it’s own ASPI layer that other software can utilize too.
The symptoms of ASPI related problems
Problems that may occur if there is no proper ASPI setup:
-The CD/DVD devices are not detected by the software
-The CD/DVD devices don’t operate correctly with some program
There are also some reports on the Internet of the ASPI layer affecting the performance of a program (like audio ripping quality) but they have not been properly verified.
Solution 1: Get the latest Adaptec ASPI layer
adaptec.gifSince the version Adaptec has been offering their drives freely for public. Their drivers should operate in any Windows version, including XP. There are however various reports of problems with these drivers. I tested Adaptec’s ASPI 4.72a2 in my computer, but programs utilizing it recognized only my SCSI connected CD drives - the IDE devices were not detected.
Download latest Adaptec ASPI
After downloading the EXE file, run it. The program asks for a destination folder, and unzips the contents there. Use, for example, C:\ASPI\ for the folder.
Next open the C:\ASPI\ folder using the Windows Explorer. Run aspichk (or aspichk.exe) and you will see if Adaptec ASPI verification can find ASPI drivers on your computer. If it says "ASPI is properly installed and fully operational" your ASPI drivers should be OK. If on the other hand it says "ERROR: ASPI is not properly installed", you need to install ASPI drivers.
To (re)install the Adaptec ASPI drivers, run aspiinst (or aspiinst.exe) and click Install. After the installation you should restart Windows, and run aspichk. You should then see the different ASPI driver versions listed, and the box at the bottom should read "ASPI is properly installed and fully operational".
Solution 2: Get the Nero ASPI by Ahead Software
acf2836.jpgAhead software also offers their ASPI layers free. They also promise support for USB/FireWire devices. Most programs should operate with Ahead’s ASPI, and there are many positive reports about the performance of this driver.
We on the other hand had a slight issue with Ahead ASPI. The Feurio! audio CD recording software wasn’t always able to lock the CD-R drive during the burning process.
Download latest Nero ASPI
Solution 3: ForceASPI
ForceASPI is based on older Adaptec ASPI 4.60(1021) version. This version of Adaptec ASPI refuses to install if there are no Adaptec products installed on the computer (Software or hardware), but the ForceASPI package solves this issue by inserting the drivers to the operating system with it’s own installer script.
Get ForceASPI
Adaptec ASPI doesn’t promise Windows 2000 or XP compliancy for the driver version 4.60, but public experience is that they work very well, even in Windows XP. On our test bench computer the ForceASPI was the best solution as an ASPI driver. It works flawlessly in every program tested.
Feb 03, 2010 | Computers & Internet
Error on my ps3
google the erro code type ps3 erro code put erro code here_
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Problem with ASPI manager
try to download aspi manager from here:
http://discinfo.rpc1.org/
also it is important to download winmount or daemon tools, they have ASPI implemented
Jul 17, 2009 | Intervideo WinDVD 5 for PC
Errpr //62-000
Does your printer havee a hard disk installed in it?
All of the pubs I've looked at reference "6X" errors as harddisk related. The "000" usually refers to a percentage that was operated on at the time of the error.
Apr 07, 2009 | Lexmark T622 Laser Printer
Tvichw32 Driver Open Error
Hello Aunt Pat
(01) Is this scanner "new" to the computer it is installed on now (where you're experiencing these issues)?
(02) Did this problem show up w/out apparent cause or relation to any recent changes on your system (e.g. New hardware or software installed, updated, upgraded or removed; system crash; computer repair; etc.)?
(03) Did the problem appear soon after a change to your system? (see above examples)
There are many references to this issue on the Internet. I've listed a few here. You can find many more, if you like, by performing search engine queries.
THIS links to a Roxio forum thread regarding this issue. (Even if you aren't using Roxio software, the information here could be relevant to your issue.)
THIS link will explain a bit about what TVICHW32 driver is.
I'd reinstall the ASPI drivers. A driver file may have become corrupted. (Assuming you'd been using this scanner successfully on this system until recently.)
You can find links for Adaptec's ASPI drivers on their web site HERE. They also have an ASPI version checker you can run to find out what verison is installed on your computer.
** Please, post back here w/ answers to
** these questions and the results of what
** you've tried. We may need to go back
** and forth a few times. We WILL continue
** to work w/ you until your problem is re-
** solved.
** Just be sure to not rate the experts' "sol-
** utions" until that time. Once you do,
** the problem will be closed and we'll no
** longer be able to assist you.
** Thank you @:)
Apr 10, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Polycom Vortex EF2280 (220012280001) Logo
56 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
