Question about Whirlpool Dryers
We have a Whirlpool Elite Dryer. All of a sudden,
We have a Whirlpool Elite Dryer. All of a sudden, the heat function doesn't work and the clothes don't dry. Is it broken?
  • preymantas May 11, 2010
    Is it new? How old is it and approx. how many loads per week do you do?
  • Whirlpool Master
  • 7,482 Answers
Sounds like your problem is the heating coil or the thermostat/thermistor. Chances are its the heating coil so I will deal with that.
If you plan to check/repair yourself then you need to unplug the dryer.
Remove the back of the dryer, try to locate the air tube from the blower to the drum. This is normally where the heating coil and thermostats/thermistor are located.
Once you have located the heating coil, remove the two wires and connect a continuity meter across the coil, you should read continuity across the coil...if you do not get a reading, the the coil is faulty and needs replacement.
Good luck,
I hope this helps
Posted on Oct 06, 2009
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Whirlpool gas dryer (LGR8648PW1) doesn't stop spinning in automatic mode.
More than likely a bad timer assembly. They are usually easy enough to replace if you have basic mechanical skills. The part can be ordered from repairclinic.com.
Jun 26, 2012 | Whirlpool Dryers
Whirlpool dryer will not heat
Gas or electric? If gas check for flame. If electric check the heater element. Go online and get a replacement. Doesn't really matter which watts you get. Should always run dryer on low setting and let the air do the work not the heat. Check the air vent and clean as necessary. You can save energy by doing loads and then adding wet clothes to dry clothes. Break up the wash load into managable sizes. Let me know.S
Apr 11, 2012 | Dryers
My whirlpool estate dryer has all of the sudden stopped heating up. What is the likely cause of the problem
I would check to see if your exhaust vent is clear first. I actually had a bird build a nest in mine once :) If that doesn't seem to fix the problem you most likely have a burned out heating element. Hope this helps :)
Apr 08, 2012 | Whirlpool Dryers
I press the start button on my whirlpool duet dryer and it beeps, but doesn't start
This is a common issue caused by a blown thermal fuse located on the blower housing and wired in series with the motor. Power to the motor is then cut and therefore cannot run. No dryer function works when the motor cannot run. Click on the link below for the complete details of the troubleshooting and repair procedure.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Aug 13, 2011 | Whirlpool GEW9250 Electric Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
MY WHIRLPOOL DUET DRYER IS WORKING BUT NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool dryer model LE5795XPWO
does it run ..if it runs and do not heat check thermal fuse.if it dont run check lid switch..alway unplug first
Dec 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
