Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Eating Tapes Mine just eats tapes, in any mode. I'm looking for parts to tune it up.
    Scholar:
  • 43 Answers
The parts you will need to fix that will be more expensive and less reliable than if you make the jump to digital storage. Buy a small portable DVR for video production. Don't get sucked into buying one with huge memory, just dump it on your computer after each use instead of using it as a long-term storage. All of your post production work will be WAY faster this way, too.
Posted on Oct 06, 2009
My Aiwa hv mk100u is eating tapes
The tape transport (pinch rollers, capstans, etc.) are sources of friction and dirt build up. Additional mechanical parts can hang up or otherwise become slow to move and cause problems. Regular use of cleaners that are contained inside a VHS tape housing can help reduce the build up on these parts and flying heads, but nothing beats a pro cleaning lubrication with denatured alcohol on cotton swabs and re-lubrication of moving parts.
May 21, 2014 | Televison & Video
Vcr is eating the tapes
THE VCR NEEDS REPAIRING.THE REASON WHY YOUR TAPE IS EATEN THE TAPE PATH NEEDS RE- ALIGHNMENT AND LUBICATED AS THE HEAT FROM THE TV WOULD OF DRIED THIS OUT.
May 02, 2010 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
One vcr is about 2yrs old the other almost new one is a magnavox the other a philips they are both eating tapes not evetytime but alot of the time.I want to copy my tapes onto dvd but afraid I will ruin...
The problem is that both machines may have the same fault, or different faults.
Eating tapes is common and multi faults can cause it. Some of the most common are errors in unloading from around the head. The capstain roller being worn. This often shows in a crinckle cut effect on the tape.
The only way to know is to take the top off and see it doing the damage. You can use a old tape for this purpose.
The most common problem is mode switch failure, this means that the video doesn't know what position it's in, hence the tape damage. However fitting a new one is very hard as the entire mechanism has to be set up right.
You might have a better chance of getting the more recent video repaired as the parts will still be around.
If you have a look at it doing the deed, then describe it here on FixYa, an expert might be able to pin it down for you.
Feb 22, 2010 | Televison & Video
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Eo1 comes on says take out battery and put back in should work but donot need to use camera now.
JVC camcorders are known for having safeguard problems.
mine was locked into safeguard the second time i tried to use it at 1 month old. i had it repaired and it came back eating the tapes. eating the tapes was blamed on old, or improper tapes. they were all brand new never used JVC tapes.
it came back from service locked in safeguard mode.
i got it back the fourth time and it worked for a few days, then went back into safeguard mode.
the shop had it more than i did during the first year.
when it locked the next time after the warranty was out, i was told the estimate for repairs was $300.00.
unless you want to try to risk taking it apart, the only 2 options you have is to send it in for repairs which is not cheap, or throw it away and never buy anything from JVC again.
i chose option 2.
Aug 27, 2009 | JVC Everio GZ-MG130 Camcorder
I have a Samsung SC L906. I sent it away to have
Ahha but if it went for service to be fixed then there is a 30 day warranty on the parts and labour you paid for Check the docket some firms even give 3 months. take some of your tapes with you so they can see the problem happening it may be your tapes are too old as well
Jul 30, 2009 | Video Cameras
Aiwa nsx-9000 is eating my tapes
Well 1st unplug it then you can start by qtip cleaning, blowing internal maintenance service. But for the most part regardless of use or age whenever there is gears, bands moving parts which in time get worn, Now this is were keeping clean extends life, So time to shop for a new 1 because repairs and part availablity exceeds the value,of your problem
Mar 04, 2009 | Audio Players & Recorders
Microcassette recorder is eating my tapes
Try cleaning the heads with a head cleaner and making sure none of the parts have become loose due to extensive use.
Jan 07, 2009 | Sanyo Audio Players & Recorders
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the motor.so remoce the mechanisum and fix with a new one.
Oct 20, 2008 | JVC COMPACT VHS-C CAMCORDER
Vcr eating tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
137 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
