Question about Canon Office Equipment & Supplies
I receive the message "cannot commuicate with the scanner"
    President:
  • 1,124 Answers
Shut the computer off.. Unplug the scanner for at least 5 minuets..
Turn scanner back on - turn computer back on..
Try your scan again..
If that did not help - un-install the scanner and re-install it..
Restart the computer..
If that did not help - call Cannon.. They will most likely replace it for you even if it is no longer in warranty.. This is what most printer/scanner manufactures do..
Best of luck !
Posted on Oct 06, 2009
CODES U1016 & U1055 1999 S-10 2.2
U1016
Loss of Communications with PCM
U1055
Loss of Serial Communications for Class 2 Devices
This is going to require special testing with a GM scanner, it is not a do it yourself repair. My guess is this you have a defective instrument cluster display
Jul 07, 2016 | Chevrolet S 10 Cars & Trucks
1998 Ford ranger when i scan the truck i get no commuication to the computer the fuse is good
What does the scanner say? Fail? has the battery been drained dead? dead battery will delete all codes
Feb 27, 2014 | 1998 Ford Ranger
Lost commuication between the remote and the TV, I changed the remote's batteries and reprogramed the remote and still not working can you assist.
This is tough to diagnose because it could be the remote or the television. There are no listings for the remote. Check to see if there is a light on the remote that comes on when you press a button to show that it is sending. Check and see if there is a light on the monitor that shows if it is receiving a signal from the remote. Usually the remote fails first. You might want to try a universal smart remote to see if it can be programmed to activate the television.
Sep 23, 2012 | Advent 15" LC-15Y3A HD Ready Flat Panel...
Windowslive messenger shuttdown every time i try to login by error name windowslive live commuications platform
uninstall it and then reinstall it before login do this Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
d. REGSVR32 Rsaenh.dll
e. REGSVR32 Mssip32.dll
f. REGSVR32 Cryptdlg.dll
g. REGSVR32 Dssenh.dll
h. REGSVR32 Gpkcsp.dll
i. REGSVR32 Slbcsp.dll
j. REGSVR32 Sccbase.dll for easy way run reg in out registry cleaner
Sep 13, 2010 | Microsoft Windows Live Messanger
The printer will not print I receive an error message
undr the scanner the is a lock.Unlock it...it looks like a switch.The scanner does not righ the home position
May 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Garmin message says "system software missing"
The firmware on the unit has been corrupted. The other problem is that the unit will most likely no longer commuicate with your PC.
The firmware needs to be reinstalled using a specific program.
Please see this link for more info on this problem.
http://www.sharc.net/discus/messages/6/273.html?1251906244
- Jim
Sep 01, 2009 | Garmin nuvi 350 GPS Receiver
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
16 people viewed this question
old marine
old marine
