Question about Dell 2200MP Multimedia Projector
I can see the through the projector but not on the computer screen - can i see both?
  • 70 Answers
Buy a video splitter if you using a desktop pc. but if your using a laptop change your setting on the display to dual.
Posted on Oct 08, 2009
Computer screen on, Projector off
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Jul 09, 2013 | ViewSonic Office Equipment & Supplies
My projector screen is showing my computer screen upside down
Your projector setting needs to be changed from the ceiling mount projection option. It is in setup menu.
Jan 09, 2013 | Mitsubishi Office Equipment & Supplies
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
The projector is ceiling mounted and connected to an HP computer which is running from a network. When the projector is turned on with out the computer or connected to a DVD the position and size of the...
On the remote control of the projector, you'll notice an "Auto Image" button (or similar to it). What it does is synch the signal between the PC and projector. You might also want to check the keypad of the projector, normally there's an Auto button on there also.
Sep 13, 2011 | Epson PowerLite 3LCD Projector
I am using a Dell lap top with Windows Vista to connect to a NEC VT590 projector. I want to show a PowerPoint presentation. As the computer is booting, the computer monitor is blank and the loading...
You need to configure the projector as a second monitor as explained here
http://www.online-tech-tips.com/windows-vista/multiple-monitors-vista/
Feb 02, 2011 | Computers & Internet
I get a blue screen on my misubishi sl1 projector lamp and no signal appears on the screen
Hi
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have).
There are also known known hot-key combinations used to switch the laptop to its external VGA mode. If you are using a laptop.
Check the cables as well if properly connected both on computer and projectors end.
Hope this helps
Apr 02, 2010 | Mitsubishi SL1 projector lamp Projector...
Searching for signal
The problem is with the computer, not the projector.
There are special function keys, generally with blue lettering along the top row of your keyboard. Find the one that looks like a double screen or says "CRT". Also locate the blue function key [FN], probably on the lower left on the keyboard.
Press, and hold, the [FN] key and press the [CRT] key to change to dual screen.... and wait for several seconds for the projector to detect it. If it still doesn't work after you have waited, press the key sequence again (there are 3 different screen settings).
1. Computer Screen only (normal)
2. Projector Screen only
3. Both Computer AND Projector screens
Sep 24, 2009 | Dell 2100MP Multimedia Projector
Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Aug 27, 2009 | SharpVision XV-Z9000 Multimedia Projector
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
Blue Screen
Select the menu and go to the input selection. set it to Computer. or manually press INPUT.
Apr 05, 2007 | Sony VPL-EX1 Multimedia Projector
Dell 2200MP Multimedia Projector Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
