Question about Ricoh Aficio AP410N Laser Printer
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there isn't anything that addresses problems with the printer. Any suggestions that could reset this error?
  • 903 Answers
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
Posted on May 29, 2010
My Ricoh GX 3050SFN displays the following error *Warning* Ppr Misfd: Int.Path Remove Paper I removed the jammed paper but the error hasn't cleared. I've power cycled the printer (about a 1000 times!)...
Welcome to Fixya.
It is possible that the feed clutch got dislodged or stuck. Locate the feed clutch in the printer and check. Also, remove the tray and locate the printer rollers. Clean it with cloth and winder. Rub it dry. Make sure there are no cloth fibers on the roller.
Hope this helps.
Nov 19, 2010 | Office Equipment & Supplies
Ricoh SP c221sf Aficio upper misfeed jam? What's that all about? There is no apparent paper misplaced anywhere in the paper path.
I had the same error. In my case one of the two springs in the paper tray was missing (on the floor behind the printer) so there wasn't enough force to push the paper up to the pickup roller. After I installed the spring the error cleared and printing resumed.
May 18, 2010 | Ricoh SP C221SF Aficio Printer
MY PRINTER STOPPED PRINTING AND GIVES A ERROR MESSAGE THAT THERE IS A MISFEED. I CAN NOT SEE THE PAPER FROM THE FRONT OR TOP ARE THERE ANY OTHER SOURCES THAT I CAN CHECK TO CLEAR THE MISFEED, IF THERE IS...
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Mar 16, 2010 | Ricoh Aficio SP C231N All-In-One Laser...
MACHINE DO NOT COPY AND GIVE THE FOLLOWING MESSAGE: (A ZIGZAG SYMBOL) WITH "FOLLOW THE INSTRUCTION"
Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
Jan 30, 2010 | Ricoh Aficio 2018D All-In-One Laser...
The machine gives a false error message.''misfeed A :internal path
Pull out paper cassett and look for paper in the feed section. Fold a sheet of paper in half and using the blue lever inside right side door feed paper between feed rollers. Make sure you do the whole width of feed section. There might be a small piece stuck you can't see.
Mar 11, 2009 | Ricoh Aficio CL7000 Laser Printer
Paper Jam
Open up the doors and blow some compressed air throughout the paper path (where the paper travels up). Make sure to blow air onto the sensors, because paper dust can coat them, causing false jams.
Does the paper get out of the tray at all? There is a feed roller that feeds the paper up into the machine; if you remove the paper tray you can see this roller -- it's big and gray and has grooves across it -- above where the paper sits toward the front of the printer. Blow air onto this roller as well, and if you have either D-ink or a rubber rejuvinator, clean the roller with a lint-free cloth.
Also make sure the paper is snug in the tray and not bent or crooked.
Feb 03, 2009 | Ricoh Aficio AP410N Laser Printer
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
Jan 30, 2008 | Ricoh Aficio AP2000 Laser Printer
Ricoh Aficio AP410N Laser Printer Logo
1,079 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
