Question about NetGear WG111T 802.11g/b (E82321) Wireless Adapter
Wg111t hi, i have recently tried to install and set up a netgear wg111t card on my computer, i finished quite quickly and was pleased with the speed of the installation, however i cannot access the internet, the signal was appearing fine and the card's drivers and software were installed... I then tried to un-install the software and it crashes half way through the un-installation...Can you help please? thanks
    Scholar:
  • 57 Answers
Hi - Well, I do have one thing for you look for -
what type of network access are you trying to set up?
I'd just reinstall the software again (don't worry about the uninstall yet) and say okay if it asks if it can overwrite the files.
With the type of card you are mentioning, you are probably going to have to set it up to access as WEP (instead of WPA's). That was what was wrong when we installed one of these two weeks ago. I was trying to connect to the WPA-personal that I'd set up the router to and already had one computer set up for. I had to change the entire network setup (including router) to WEP to accommodate the new connection! (And WEP is slower than WPA's.)
I hope that is the only problem for you.
Posted on Dec 23, 2007
Can't set up Netgear WG111v2 wireless adapter
You can download the software you need from Netgear's site. All the download and installation instructions are in one place for you.
May 26, 2009 | NetGear USB 2.0-Stick WiFi 108 Mb WG111T...
Netgear wg111T Wireless Adapter 2.0 connectivity issues
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jan 02, 2009 | NetGear WG111U 108 Mbps Wireless USB 2.0...
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear Wireless USB Adapter wg111t; installation
Hey there Kjantzi, I have found the site for Netgear, and as I read it the update is one of the options but the drivers and firmware are there as well. Check here:
http://kbserver.netgear.com/products/WG111T.asp
Choose the version for your OS on the left, and it gives you detailed instructions, including the update process, if needed. If you still have problems let me know. Good Luck!
Mar 27, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
WG111T config problems
http://kbserver.netgear.com/release_notes/d102803.asp
Download version 1.3
I was running into the same issue when I formatted my computer. It worked fine before that. I downloaded the version 1.3 though and it installed easily. There are step by step instructions how to install it as well. Hope this helps!
Jan 29, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
WG111T
The solution I have is quite simple. I use Vista premium x64 so someone else can test it on Xp but it should work for both. In Vista the 1.3 version doesnt work so Facid's solution doesnt work for me.
[LIST=1]
[*]Get the 2.1 setup for Vista and install it.
[*]Go to your NETGEAR folder wherever you installed it to (Program Files x86 for me) and copy the DRIVERS folder to your desktop.
[*]Uninstall the smartwizard and remove everything in the NETGEAR folder.
[*]Plug in your WG111T.
[*]Go to Device Manager and find your WG111T in the list, Right Click and Update Driver.
[*]Browse to the DRIVERS folder on your desktop when it asks where to look for the driver and the WG111T will install. It should popup with a little message when it is completed but you will not be online yet.
[B]I dont know what you would do in Xp x64 system but I believe it has its own wireless manager like Vista and should be quite simalar.[/B]
[*]IN VISTA go to the Connect To button in your Start menu, It should be under Computer and Network, it should show your router along with a 5 bar network strength graphic.
[*]For me all I had to do was double click on the network and put in my WEP hex key and it conected.
[/LIST]
Gamertag: NeoNMD
Nov 04, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
NetGear WG111T 802.11g/b (E82321) Wireless Adapter Logo
157 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
