Question about Kenmore Oasis HE 27082 Top Load Washer
Washer did not sin clothes, I ran a rinse and spin cycle, it skipped from 17 minutes to 4, never did spin fast and showed an oL on the screen
  • thecrenshaws Oct 06, 2009
    I ran it through a clean cycle with no clothes and got the same result...It appears that it is also not filling with or without clothes. It sprays water, then spins slowly and drains...it jut continues that cycle
    I have run the machine with a smaller load and with no load. It is not washing the clothes, it sprays water, spins slowly and drains...it just keeps repeating the same thing
    President:
  • 1,884 Answers
Please check the IC that controls the spin cycle.
Posted on Oct 07, 2009
  • 3,741 Answers
There are two possibilities for OL error on the display screen
1)there is over load of clothes getting washed in the machine.so it shows OL on the screen.because the motor is not able to spin the clothes due to this load.
2)The OL error code means that the lid is either open or something is keeping it from shutting all the way. The washer will agitate but it will not drain or spin dry.
so remove all the clothes clean everything in the maschine if its blocking like clothes or any object blocking the motor to spin.
or the lid is not getting closed check out the lid if its cracked or broken or getting blocked.
this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 06, 2009
  • charlymonty Oct 06, 2009
    that means the fill valve is faulty.
    The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
    No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
    Slow fill - A fill valve has screens built into it to prevent sediment from entering the fill valve. Sometimes these screens can get plugged and will need to be cleaned out with a old tooth brush. Just shut off the water, remove the hot and cold fill hoses and clean out the screens on the entrance of the fill valve. When ever possible, you should try not to remove the screens from inside the fill valve entrance. The screens are in the entrance of the fill valve. If the screens are just too clogged or if you have removed them, install new screen-washers in the fill hose end to prevent junk from getting inside the fill valve. If all attempts to clean the fill valve has not helped the fill pressure. Sometimes the fill valve can be damaged and this is why it won't fill as fast as it used to, you may have to replace the fill valve.
    check out.thanks.keep updated.
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Washer stops and shows oL over load
The "oL" error code in the Cabrio and Bravo washers means the motor is sensing an overload ("oL") condition. While this could indicate a problem with the motor, it usually doesn't. Most of the time, you'll see this error code when one of two things is going on:
1) There's a piece of clothing stuck between the inner basket and outer tub.
2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job.
Here is a video to help you get into the machine.
Keep me posted!
Nov 01, 2012 | Whirlpool Washing Machines
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
254 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
