HI, I have an Acer Aspire AM5641-B5540A. THE SYSTEM IS COMPLETELY DEAD. i HAVE RULED OUT A BAD POWER SUPPLY. WHAT DO YOU THINK COULD BE THE PROBLEM?
  • Ernal Mckenzie
    Ernal Mckenzie Oct 06, 2009
    I took that power supply out and put it in a similar computer and it ran fine. I also took the power supply out of he other pc and put it in the problematic computer and still no power.
  • Hank May 11, 2010
    Hi, Please let me know how you determined that the power supply was ruled out. Hank
  • 433 Answers
I understand now that you really checked out that power supply. Before we rule out a dead mobo, you should make sure the on off switch on the computer case is not broken.
Look on your mobo and find the power switch leads from your case power button to your mobo and remove them. Short out these two pins with a small screw driver and see if computer goes on.
http://www.pctechbytes.com/troubleshooting/detail.php?How-to-Bypass-A-Motherboard-Case-Switch-8
If that fails, and you checked your memory and CPU, then well, R.I.P. motherboard.
Hank
Posted on Oct 14, 2009
  • mike_hogue20 Sep 18, 2010
    i had the same problem but my lights worked. i changed out 2 different power supply,s and the second one worked the old one came on but nothing on monitor.
    Sergeant:
  • 191 Answers
The cause may be fried motherboard
Posted on Oct 06, 2009
Acer aspire 4317z does not power
It's either your motherboard is dead or the power supply is dead.
If it's the power supply chances are your motherboard is dead as well now, if it's the motherboard then chances are your power supply is still good and it was just the power supply, but sometimes the power supply will take your motherboard with it as well.
It's hard to completely test these things without having correct equipment.
You should take it into a shop.
Feb 26, 2013 | Acer Computers & Internet
Laptop Acer Aspire 3354-1096 Power-up Problem
Do you have access to a multimeter to track the AC/DV current? If the power is getting to the laptop, correct DC/AMP voltage? AC jack been damaged, pulled, yanked...etc? Hard to say which component without checking with a multimeter? PSU?
Nov 25, 2012 | Computers & Internet
Acer aspire 5552 completely dead no power lights or nothing charger works fine
try replace your power adapter,i think that problem in ur power adapter
,,try it
May 30, 2012 | Acer Aspire 5552-3691-24271 Laptop
No power
Its looks ur power supply problem so change ur power supply then it will works fine
Jul 26, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5610Z dead battery & malfunctioning power adapter
But before you buy a new battery, You need to again repair the power plug where your adaptor's plug is inserted so that it will not create any problem later. There might be loose connection or sort wiring.. Good luck..
Apr 29, 2010 | Acer Aspire 5610 Notebook
ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
Apr 02, 2010 | Acer Aspire 7520-5185 Laptop
No power, No beeping, nothing completely dead.
Replace the power supply. Even if the power supply is powering on, it sometimes will not have enough voltage to power the system.
Good Luck
C2Solutions
Mar 05, 2010 | Acer Aspire™ T180 PC Desktop
I need to find a replacement motherboard for my Acer Aspire AM5641-B5540A, and am not having any luck. Can someone point me in the right direction, please?
Out of luck - most MB models are only available for 6-8 months, then a new board comes out. You will need to start with a new board.
Feb 22, 2010 | Acer Computers & Internet
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Can I add an internal graphics card to my Acer computer? AM5641-B5540A E2200?
yeap..
look for pci express graphics card (dedicated)..
better to have 'sli cross-firing'..
seek supervision of ur system admin/vendor....
Nov 10, 2009 | Intel Motherboard
Computers & Internet Logo
1,642 people viewed this question
David Payne
David Payne
