Question about Dehumidifiers
My GHD30 just will not start any more. could it be a fuse? or something worse? switched outlets, same problem. worked fine and then just bit the big one...
  • 70 Answers
If it blow fuses or breakers and the start switch on the compressor is god the you may have a lockup compressor,the unit then would be a boat anchor.
Posted on Oct 06, 2009
What size hose should I use for the continuous drain operation?
1/2 inch hose , --bit of garden hose or clear plastic from the hardware shop
if 1/2" is too big measure the outlet pipe and get plastic hose to suit
May 28, 2016 | Arctic King 50 Pint Dehumidifier
Model GHD30 will not run. Have power to the board. I can hear a click noise when turning the switch on. I electricially checked the compressor and fan both ok. PCB board?
Jim, you may also want to check the water bucket installation, too. If it is not properly installed, the unit will not turn ON. Also, check the float valve in the top of the bucket. It may be stuck in the UP position. In which case the unit will not start. Giggle the arm of the float valve to get it to return to the DOWN position.
Hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 27, 2011 | Goldstar DH504EL Dehumidifier
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Apr 28, 2011 | Dehumidifiers
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
Goldstar ghd30
Make sure condenser is clean.
Apr 10, 2010 | Goldstar DH304 Dehumidifier
GHD30 - how does i connect a hose to the bucket? i don't see a whole in the bucket which others have mentioned is there.
you probably have a hose fitting above the bucket take bucket out and see if there is one where the water drains into bucket
Jul 25, 2009 | Goldstar Dehumidifiers
GHD30 dehumidifier completely dead
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Nov 01, 2008 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
Dehumidifiers Logo
91 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
