Question about Canon Rebel XT / EOS 350D Digital Camera
My digital Rebel is not focusing the lens correctly
My digital Rebel is 4 years old and has been working great but now it doesn't seem to be focusing the lens correctly. I have tried to change lenses and that doesn't help.
    Scholar:
  • 43 Answers
Frequently the cause for these problems regardless of the camera manufacturer is either the small, brass connections are dirty, the back glass of the lens is dirty, or the reflector is dirty. Use caution when cleaning the glass, only use the proper cloth. Same goes for the reflector.
To clean the brass connectors use a foam tip Q-tip or very very carefully use a regular Q-tip. Dip it in 99% alcohol (NOT regular isopropyl alcohol, it's only 70% and contains water - not good! Be sure to check the label!) Once the contacts are clean on both the camera body and the lens, allow them to dry thoroughly (which doesn't take long outside, but any alcohol that got in the cracks may still be wet.). Not allowing the parts to dry completely can cause them to short out, then you've go bigger problems. Just a little patience goes a long way!
Good Luck!
Posted on Oct 06, 2009
Auto focus not working
I just have to ask sorry if it sounds stupid.. check to see if the lens is switched to auto focus.. I have seen this alot and there is a switch on the lens that says af or m .. lets me know if this doesn't work and we can go from there
Nov 16, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel T3 focus problems
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
Sep 01, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Our Canon EOS Rebel XSi no longer works on auto focus. The flash works but the camera just makes clicking noises and the screen says "busy". Any suggestions? The camera works fine in manual...
Optical focus relies on a gear driven motorized system to focus the lens. It sounds like the drive is either frozen by a foreign object (it doesn't take much) has gotten into the system, or a tooth has worn/broken on the gearing.
Try taking the lens off and blowing the camera out with some canned air. If that doesn't do it, it's a trip to the repair center.
Jul 04, 2011 | Canon EOS Rebel XSi Digital Camera
I have a Canon EOS Digital Rebel XT with the original 18-55mm lense and a Quantarey 70-300mm lense. Have had all pieces for 3 years now and everything worked great until last night. Camera focuses and...
This means that the communication with the Quantarey lens is not the right one.
You can try in cleaning the lens contacts and the camera contacts with a pencil eraser or a white erase (flip down the camera so no particles get inside the mirror box).
If still you are having problems, then that means the Quantarey lens is defective, and either needs to be service to be repaired, or you will need to get another zoom lens.
Best regards,
Jul 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lack of focus
I knew the problem was with the auto focus. First time I called the camera shop..they said "bring it in, we'll diagnose it...for about $200.) I tried a cvouple of days later...he said they would trouble shoot for free.
HOWEVER...he said to check to see that the lens was seated securely and correctly. I had taken lense off a few weeks ago and it was not reinstalled correctly. One small twist of the lens and back to perfect forcus!
May 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus isn't working
Check the lens. If the switch is set to MF then it is in Manual Focus.
Another cause could be custom function 4 - try setting this to 0 for the default
Apr 08, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Automatic Function will not work!!
I had the same problem a few moths ago when I tried to use a Quanta lens. Go into the second tools menu, select clear settings, then select Clear all Custom Functions. It worked for me I hope it works for you.
Oct 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
114 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
