Question about Canon PowerShot S1 IS Digital Camera
Blur image in viewfinder and LCD display
I didnt use my cam in last 1.5 months, when pulled out today the image on display screen is appearing absolutely blur, even through the viewfinder I can see the blur image - I can hardly make out what the image is. The picture is also coming blur, must have some problem with lenses it seems. I dont think my cam got wet or something. Please suggest how to fix it.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 26, 2007
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Sony DCR-TRV250E.
was the problem the lense cap, or you do still need assistance?
Mar 28, 2008 | Sony Handycam DCR-TRV19 Mini DV Digital...
When in video recording mode LCD screen and viewfinder are black when the lens cap is off.
It could one of a few problems:
1. The viewfinder is pulled out and "PRIORITY" is set to "FINDER".
Push the viewfinder back in or set "PRIORITY" to "LCD".
2. The LCD monitor's brightness setting is too dark.
Adjust the brightness of the LCD monitor.
3. If the monitor is tilted upward 180 degrees, open the monitor fully.
Download the manual for more info:
JVC GR D290 Manual
Jan 19, 2014 | JVC GR-D290 Mini DV Digital Camcorder
S1IS canon camera
Apparently the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all.
To determine if the CCD (image sensor) is working properly, follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe
the LCD.
a. If the images are displayed properly, please proceed to step
four.
b. If the images are not displayed, or a "NO IMAGES" message
appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists
with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode
(i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or
viewfinder. If the scene the camera is pointed at appears on the LCD
and/or viewfinder, the CCD is operating properly. If the LCD and/or
viewfinder remain black, the camera requires service.
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, products exhibiting the above-mentioned
malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Regards.
Dec 01, 2009 | Canon PowerShot S1 IS Digital Camera
Dark and blurry
It will clear instantly with a fresh battery.
The viewfinder screen has an LCD overlay and even when the camera is switched off the screen uses a small amount of power. When the batteries are flat the screen is unpowered, the crystals in the LCD align randomly to both darken and blur the viewfinder image.
Please don't forget to rate my answer.
Jul 18, 2009 | Nikon N65 35mm SLR Camera
No image in viewfinder or on lcd screen
This is a very common problem which affected millions of cameras manufactured using Sony's 5MP CCD. The symptoms you describe are absolutely classic but to confirm it try viewing older shots taken before the problem arose using your camera's LCD: they should display as normal.
Contact Sony in your country: they have been offering free repairs for this problem, my 2004 Sony DSC-V1 was repaired under the scheme last summer.
When you get your camera back, be on the lookout in the few months afterwards for what look like water droplets on every picture. These indicate a faulty repair where the technician has got something on the CCD and Sony won't accept responsibility for further remedial work after a certain mount of time. I found out the hard way when I noticed this second fault last month but Sony said I'd left it too long before notifying them!
Jul 15, 2009 | Nikon Coolpix 5700 Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
NO PICTURE ON LCD SCREEN OR VIEWFINDER
model # is required for me to help you.
Sep 09, 2007 | Canon DC10 DVD Camcorder
No image displayed through viewfinder or lcd screen
could be one from a batch with faulty CCDs - check out this fixya link (solution 2) - http://www.fixya.com/support/t115316-canon_mv30 - it's copied from a page at imaging-resource.com - my MV600i was out of warranty and I sent it back to Canon at the end of 2007 and they got it going again free of charge within the week - unfortunately within weeks a very similar fault appeared and now they're trying to charge me for the repair !!! even though they say repairs are under warranty for six months -
May 23, 2007 | Canon MV600i Mini DV Digital Camcorder
Malfunction?
If the LCD display is open, the viewfinder becomes inactive. Shut the LCD display, and the image should appear through the viewfinder. If there is still no image, the camcorder may require service.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon PowerShot S1 IS Digital Camera Logo
174 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
