Question about Onkyo DX-C390 6-Disc CD Changer
Won't work It turns on and displays "Mech error" on front. The disc table will not come out . It will not play. It will not move from disc to disc. I've unplugged it , but cannot get it to budge. Please help. It is only one yr old. Jeff Peters
  • 3 more comments
  • jethro46 Dec 23, 2007
    exactly right. I took the cover off and a disc was jammed. It is working properly now. thanks a bunch . Jethro
  • caseywagner Dec 30, 2007
    Have same problem. Are there instructions for taking the cover off?
  • caseywagner Dec 31, 2007
    Fixed it fine. Just took the top metal cover off of the unit and fixed the disc that was out of its tray. Really easy and no electronic experience required.
  • AMencher Mar 24, 2008
    yes, many thanks for this advice. Opened it up, even let my 4-year-old help and found too many CDs all messed up inside. this post saved my chucking or paying $75 to get it "fixed." Now if I can just get the kids to stop jumping around the player to stop the discs form skipping!
  • hman66 Feb 03, 2009
    Guys, I have the same problem. "Mech Error" and it too is most likely a jammed disc. My question is....did you take off the front face cover? It has 4 screws on the bottom, I took them out but the front cover is hard to get off and I don't want to break it. The unit is hard to get at for me to see (professional RI install etc.) so, I don't want to try to pull it out until I hear from someone. If it is the main encasement you are talking about. Would you be so kind as to detail the process? Many thanks...HMan
    Problem Solver:
  • 9 Answers
Sounds like there might be a disc jammed in the disc tray.
Posted on Dec 23, 2007
Sony CDP CX300...new belts, mechanism gets disk, places it in front of the spindle but the spindle doesn't move toward it and the disk is put back in carousel.
These models often get broken loading parts in front of the pickup assembly. If you could take a good picture of the front of the mech, I may be able to identify what is broken.
Sep 01, 2015 | Sony MegaStorage CDP-CX355 300-Disc CD...
Table Error
After replacing belts, turntable moves to position disc 1 in front of loader then swings back and forth 10 times and posts "TABLE ERROR" again. If I apply slight clockwise pressure to table, then disc loads OK. On unload, table rotates to position disc 1 in front, door opens, then table oscillates another 10 times and posts "TABLE ERROR" again. Any hints?
Feb 03, 2014 | Sony CDP-CX335 300-Disc CD Changer
"CDC MECH ERROR" on 2009 Honda CR-V EX-L with Nav
Either the unit's motor is bad or the mechanical parts are dirty not allowing the unit to change CD's or load them.
Jan 23, 2014 | 2009 Honda CR-V
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
Sony slv-d370p displays dvd_errlog5 message
You`ll find the error codes in the service manual, But I don`t think this will help you, it sounds like you have a compatability problem. Are you not better connecting your turntable up to your PC?? You can purchase these really cheaply out of ASDA and other good retailers now which will plug directly into the USB port. You`ll have no problems then, I promise, I`ve done it. Ian
Has it actually wrote to the disc and have you finalized the disc?? Does the disc look like it`s been wrote to, you can usually see the recorded section of the disc but if it`s not been finalized, It`ll never play on a normal CD player. A CD player requires the TOC (Table Of Contents) in the centre of the disc, if this is missing, the CD will just give up and say disc error or something similar. Ian
hope this helps,thank you
Feb 10, 2011 | Sony SLV-D370P DVD Player/VCR
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Won't stay closed
even if the laser lense cant process the data being read it should not eject and just display disc error or no disc. That's how it normally does. anyway if is is different from yours, try cleaning the laser lense with cotton bud, dampen a bit with rubbing alcohol, then the other end to dry it. rub it in circular motion please and not too hard or excesiove force on it.
lubricate the spindle motor shaft if you can reach, not too much oil, the very thin type household use only. likewise the traverse mech. the mech is not the source of your problem but since you are lubricating the spindle motor then you might as well lubricate the rest of moving parts. try not to put oil in you platine table and other rotating parts like the rubber belts or you'll find another problem later.
Reden
Dec 12, 2007 | Yamaha CDC-502 5-Disc CD Changer
Onkyo DX-C390 6-Disc CD Changer Logo
1,067 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
