Question about Cameras
Turn on camera and no image, every thing else seems normal
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please intimate model number of your Sony digital camera. Thanks.
I have sony v1, unfortunately it was dropped, now the problem arises that you can see previous stored pics in lcd but when you want to capture the image, nothing is displayed and if you take the picture it...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected which displays the live view of the Camera and the image which get captured. If the Image Sensor is affected, the previous views of the images and the icons will get displayed as normally, but the live view and the captured images will be distorted or blacked out. You may try power resetting to check if the issue can be resolved.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Feb 24, 2011 | Sony Cyber-Shot DSC-V1 Digital Camera
I SEE the green light when I turn on the camera but LCD screen of Sony DSC-F505V is dark black, nothing happens-total silence and cannot take any pictures. Did I loose my camera? Solution?
Based on the information provided it seems that the issue may be with the LCD Screen. You can check if the Camera is working by capturing images and inserting the Memory Stick in the Computer Memory Card slot. If the image capturing is normal then the images can be saved to the Computer. If the images are not getting captured, then the issue may be with the Camera. We can try power resetting the Camera to resolve the issue.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
If the issue persists after resetting, then service may be required to identify the exact cause.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-F505V Digital Camera
D80 Monitor does not function as view finder.
To be able to do what you want, your camera would have to have a feature called "live view"....yours does not.
Jul 21, 2010 | Nikon D80 Digital Camera with 18-135mm...
Olympus Evolt e-510 vibrates when turning the camera off
it's the anti dust filter and you would have known if you had rear the manual !
Feb 24, 2009 | Olympus EVOLT E-510 Body Only Digital...
Cyber Shot DSC-T1, Possible CCD Problem
When ccd imager is defective, picture result on still image and video get bad in either cases.
Your camera problem is some thing different and hardware failure is possible like data processing IC but in any case, digital processing board has to be replaced and I'm sure its price would be above and over the camera worth.
You can give try by removing and plugging back the flexible wire board ( ribbon) of lens and ccd imager attached to circuit board. Be careful when handling as flexible wire board can be damaged easily.
Thank you.
Oct 06, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Nikon D40 Image Darkness
You probably have "bracketing" turned on. In your menu settings, search for bracketing and make sure it is off.
Feb 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
