Question about Oceanic Delta 4, Air XS, Islander BC and VT3 w/ trans
My islander inflator valve sticks, where can I get repair information and parts?
  • 36 Answers
Try an Oceanic Dealer or contact the company for return instructions.
Posted on Aug 19, 2010
Inflate presta valve
to inflate a presta valve you need to yurn the top part of the walve counter clockwise at least 3 turns. the pump you are using must be for this type valve,or you can by an adapter. spin pump nozzle on to valve, add aie , remove and tighten top of valve. presto!
May 08, 2014 | Trek 4900
Saeco Milk Island
I dont think that there is a such diagram on the web.It is easier to see how it is inserted looking an assembled appliance.
http://shop.technikdirekt.de/es/a-haushalt+kleingeraete+espressomaschinen+zubehoer+123179/Saeco+Milk+Island
Feb 14, 2008 | Saeco Milk Island Automatic Frother -...
Lost air stopper
Nothing helps. Get a polypro kayak that doesn't need inflation!!!!
Mar 29, 2014 | Challenger Intex K1 1 Person Inflatable...
Just got a Skedaddle 2 XC Inflatable Kayak and having trouble trying to inflate it at home to see how it works before going out on the water. Don't know which tip to use on the foot pump or where to use it...
Use the threaded tip for the two main chambers, but be sure to turn the inside part of these valves clockwise to put them in the inflate position -- just press your finger on the valve and turn (the instructions aren't very clear on this). To deflate, push the valves in and turn counterclockwise.
For the orange twist valves use the tip that fits over them -- there is only one that fits snugly over them. Don't forget to open the valves (turn counterclockwise) before inflating and then close them (clockwise) before removing the tip. Just turn then cc to deflate when you're ready to put the kayak away.
I was able to inflate the Skedaddle 2 in less than 7 minutes on my second try, and I wasn't rushing at all. It's really pretty easy once you get the hang of it.
Mar 20, 2011 | West Marine Skedaddle 2-XC Two-Person...
When I'm pumping it up the ball sticks and will not inflate. I hear air coming out from the ball you squeeze.
If this is happening when the finger valve is closed, there is a leak either in the rubber tubing or the inflation bulb. Try putting soapy water on the tubing and then on the bulb. Squeeze the bulb with just your thumb and forefinger, so that you can see any air bubbles. If the leak is in the rubber tubing, you may be able to repair it with a couple of laps of vinyl tape. If the bulb is leaking, that will have to be replaced.
Hope this helps you solve the problem.
Mar 18, 2011 | Health & Beauty
Milk island does not foam milk. i have the switch in the right position. how do i set the two part valve on the milk island?
Clean the milkisland valve,that is on top of the jug.Careful not to loose the small rubber valve which control the air to make foam.To set valve, one side for hot milk, and the other is for foam.
Jan 19, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Hoveround rear tire needs inflating
I don't think you have an MPV4. That model has 2 rear caster tires that are solid and require no inflation. The front drive tires have a valve stem sticking out of the center rim that is easily accessible. Make sure your power chair is gray and says Hoveround on it.
Apr 24, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Oceanic Delta 4, Air XS, Islander BC and VT3 w/ trans Logo
80 people viewed this question
Top Oceanic Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
