Question about General Plumbing
Velocity variation (or flow pulsation) of a reciprocating pump
How can i calculate the variation of velocity (or flow rate) above mean and below mean in the discharge line of a reciprocating pump?
  • 523 Answers
Please see the attached link, this may aid you.
http://www.1728.com/flowrate.htm
I hope this may have helped,
Tom
Posted on Oct 10, 2009
What is the velocity of BBs?
Varies, of course, with class and model, but:
"Lever action models generally have very low velocities, around 84 m/s (275 ft/s)..."
"The Daisy Model 25 pump-action BB gun typically achieved the highest velocities of its day, ranging from 375 ft/s (114 m/s) to 450 ft/s (140 m/s)...The re-issued version... has a muzzle velocity of approx 350 ft/s (110 m/s)."
http://en.wikipedia.org/wiki/BB_gun
http://en.wikipedia.org/wiki/Daisy_Model_25
May 01, 2015 | Optics
The spindle of a mixer rotating at 1500rad/min slows down uniformly to 700rad/min while making 40revolution,. Calculate the angular acceleration
Use the equation linking the final angular velocity and the initial angular velocity
(omega_final)^2=(omega_initial)^2+2alpha(theta_ final -theta_initial)
Each revolution is 2PI radians.
Dec 26, 2014 | Office Equipment & Supplies
How to calculate coefficient of variation on TI-36XPro
As given in part three of the question, divide the standard deviation by the average then multiply by 100.
Sep 20, 2014 | Texas Instruments TEXTI36XPRO TEXAS...
Calculate the speed of the wave that has a frequency of 3 GHz and a wavelength of 4mm
For a plane wave in a homogeneous medium, the phase velocity of the wave is related to the frequency and the wavelength by the relation
velocity = wave_length*frequency
In this case
velocity (in m/s)=(4*10^-3 m )*(3*10^9 s^-1)=12*10^(9-3)=12*10^6
Thus velocity=1.2*10^7 m/s
Nov 28, 2013 | Office Equipment & Supplies
Vibration when accelerating from stop
Acceleration is the rate of change of velocity over time. When you are braking, you are changing the velocity of the vehicle you are in. That means that when you are braking you are actually accelerating.------------------------------------------------------------------------------------
Launch X431 Master
Mar 07, 2013 | 2003 Ford Expedition
Using the formula developed by brier and panofsky,determine the storm central pressure if the approximate velocity velocity of winds at low pressure area is 40 knots
Panofsky and Brier methods is normally being used for the conversion of barometric pressure to speed in m/sec or to nm/hr (knots). Being a professor in a maritime schools for this lesson, i encourage students to understand this.
P&B Methods:
If you use SVPAM Calculator
(1016-PO)= square root = x 3.5 + 3.9 = velocity in m/sec
PO = Pressure Observed
so practical.. :) SIR JAPZ
Jan 24, 2013 | Casio fx-300ES Calculator
How to set velocity on tippnan 98 custom
There is a velocity adjuster on the left side of the body, just below and to the right of the "N" in "TIPPMANN."
In order to adjust the velocity you need to be in a place where it is safe and legal to fire your marker (paintball field, with all bystanders protected by netting or paintball goggles.) You will need a chronograph and a 3/16-inch hex wrench.
The adjuster is a screw that blocks the gas flow from the valve to the bolt. If you screw it in (clockwise) it blocks more of the gas, so your velocity goes down. If you screw it out (anti-clockwise) it blocks less gas, so the velocity goes up.
Just take a shot over the chronograph to check your velocity, adjust and check again until you get it where you want it. Most paintball fields limit velocity to 285 feet per second. Never go above 300 feet per second, as velocities above that are unsafe (beyond paintball goggle ratings and can cause damage and infection on skin due to the heavy impact.)
It is important to test and adjust the velocity before each day of play, and even multiple times during the day as weather changes, because it is affected by temperature.
Jan 19, 2013 | Tippmann 98 Custom Act Paintball Gun
Hi I'm trying to find the reciprocal sign on my Casio fx-300es
If you mean "1-over-x" then it's the key marked "x-superscript-negative-one" just right and below the big round cursor pad. If you mean "reciprocal sign" more commonly referred to as "negative" or "change-sign" then it's the key marked "(-)" two keys above the "7" key.
Aug 09, 2011 | Casio fx-300ES Calculator
How to get the average of the velocity if motion is under constant acceleration
Take the example of a racing car as pictured in the animation above. It takes the vehicle 10 minutes(0.17 hours) to travel 23km, from start to finish.
Average speed = 23km / 0.17hrs = 135.29km/hr
Average velocity = 4km / 0.17hrs = 23.53km/hr
The average speed is 135.29km/hr but the velocity is only 23.53km/hr. The reason that velocity is lower, is that it can be positive and negative. Remember this from our earlier discussion on velocity? If not,click to refresh your memory. Since the velocity has negative and positive values some will cancel each other out, hence the lower value. Speed, however, can only be positive.
Jul 19, 2011 | Adobe Computers & Internet
A bob of mass 50 g oscillates as a simple pendulum with an amplitude 5 cm and period 2 s. Calculate the instantaneous velocity of the bob and the tension in the supporting thread when the velocity of the...
1. i) A bob of mass 50 g oscillates as a simple pendulum with an amplitude 5 cm and period 2 s. Calculate the instantaneous velocity of the bob and the tension in the supporting thread when the velocity of the bob is maximum
Mar 10, 2010 | ACCO Brands Air Tools & Compressors
Plumbing Logo
95 people viewed this question
Top General Plumbing Experts
ka4iup
ka4iup
Gil Shultz
Marty Shuman
Marty Shuman
Are you a General Plumbing Expert? Answer questions, earn points and help others
