How to replace the sony housing module with lamp
Price for XL-2400 sony replacement lamp with housing for KDF-E50A10 Grand Wega
You can get them from many places but you want to get the lamp with housing most places only sell the bare lamp annd then you have to install the new lamp into your housing being careful not to touch the lamp . You can get the Sony XL2400 lamp with housing from www.tvrepairworld.com which is 159.00 and includes installation instructions which takes about 2 minutes and no special tools required when you get the lamp with housing as an assembly.
Aug 13, 2011 | Sony Televison & Video
I have a Sony TV - KDF-42E2000 and the lamp went out. Replacing the lamp looks to cost around $80 but replacing the lamp with all the housing for it is around $250. Do I really need to replace the...
I have a sony KDF-42E2000 and our lamp went out a yr after we purchased it. I found the lamp with out the housing on eBay and there was a video on how to take the old lamp out of the housing and replacing it with the new lamp. Now I am a female with NO experience with doing that type of thing, but I was able to do it with ease. So you can swap just the bulb. Also we just had to replace the lamp again and this time on eBay there was the lamp with the housing for 91.00. Easy as pie... But now the problem is that there is a red band across the top of the screen. Just got off the phone with Sony and they said that to fix it, it was going to be around 1K but they will let me choose between 2 different TV's at a reduced price. Apparently there has been a lot of issues with the TV's to the point where this is what the specify in the email: In consideration for Sony making and you accepting this offer, you agree to release and hold harmless Sony Electronics Inc., and its affiliates, officers and directors from any and all claims for damages, loss, cost, expense or liability both known and unknown, which you may have incurred in connection with your television.
So no matter what you decide as far as lamp vs lamp and housing, be aware you might end up contacting sony at 800-200-SONY to get an offer of a discounted tv.... Good luck!
May 20, 2011 | Sony KDF42E2000 42" HDTV
How do I chage the lamp? Do I have t ochange the housing too?
Replacement lamp comes along with housing and lamp replacement procedure is easy, written in user manual, click Sony Support link to download user manual free copy and check page-51 for detailed instructions.
Required lamp part number is as follows:
F93088600 ..... LAMP BLOCK ASSY XL-5200
Available in Sony Accessories Store for $250
Thanks.
Nov 15, 2010 | Sony KDS-55A2020 55" Television
Sony projection television lamp replacement...
hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Nov 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Picture goes blank AND SOUND goes off together, both back on too
it can still be the lamp for some reason these sony tv's will exibit these symptoms when the lamps are getting weak. by the way when the lamp goes out the entire tv shuts off no video or audio, just to let you know.
Aug 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    SONY KF-50WE620 LAMP
    A-1606-034-B is correct. Make sure you are buying a Sony Original replacement though. A lot of knock-offs are not correct.
    Sony KF50WE620 Replacement Lamp
    Jan 31, 2009 | Sony Grand WEGA KF-50WE620 Television
    Bulb Replacement for Sony TV KDF-42WE655
    no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
    Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Replacement lamp
    The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
    http://rearprojectionlamps.com/2000u-lamp-p-2277.html
    Dec 12, 2007 | Sony XL-2000U Projector Lamp for XBR800...
    Sony kdf-60xs955, rear projection tv
    There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
    Jun 19, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
    Televison & Video Logo
    22 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
