Question about Microsoft Xbox 360 Console
NO SIGNAL BEING SENT TO MY TV ..BY HD OR AV CABLES
    Novelist:
  • 168 Answers
This is a common fault with the 360, it says that its a "general hardware
failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat
and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 or even no sound but
graphics or sound and no graphics just like you are reporting.
Firstly get a spare AV cable from someone else, try this, if that does
the same then try a different SCART
input on the TV. if all this fails you need to fix your machine as it
WILL get worse
You will need to get a 3rrod repair kit or get someone to fix it for you,
there are guides available on the
internet. I'm in the middle of producing one right now that I will make
available free of charge for all fixya
members.
Linda
xboxrepairkit
Posted on Oct 10, 2009
I have a 42 inch led tv bought T Xmas
It usually matches the signal being sent to it. the movie etc. is 4:3
If you have a hi def cable/fios etc box you need the HDMI cable or the 5 AV cables to actually watch it in HD then this should stay at 16: other wise your stretching the picture makes people look funny
Hope this helps, God Bless :O)
Apr 24, 2014 | Toshiba Ct90325 Remote Control
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
My xbox is running but there seems to be no signal being sent to the tv, what could be wrong?
tv/av cables could be faulty. unplug it with xbox on then plug it back in. if you can hear sound in background then its your video cable. if you have the HD cables make sure the switch is on right setting, located directly on the cables themselves
Sep 25, 2009 | Microsoft Xbox 360 Console
Nintendo Wii AV Cables not work
It could be a problem inside the Wii where it only outputs a signal through HD. Have you tried a different TV using the original cables? If the problem persists I would recommend calling Nintendo.
Jul 27, 2009 | Nintendo Wii Console
Connected to a sat. we have no sound when we put the T.V. to H.D
What cabling are you using? component? (blue red and green) or HDMI? if you are using component then make sure you also plug the red and white RCA cables in the "audio in" inputs. People commonly think that the component cables do it all but they only carry a video signal. If you are running HDMI through an AV reciever you may need to run an optical cable as well as most AV recievers (unless you buy top of the range) can only switch HDMI video but not sound.
Jul 05, 2009 | Televison & Video
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
74 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
