Question about Garden
Connecting rod bolt torque and cam to crank timing on a 16.5 ohv model#310707 type#0137-E1 rider mower engine
  • 389 Answers
connecting rod bolt torque and cam to crank timing - moz-screenshot.jpgmoz-screenshot-1.jpgRod bolt torque is 150 INCH POUNDS - - NOTE: INCH POUNDS NOT FOOT POUNDS
Valve timing is generally performed by matching either a dot or dash mark on the cam gear with a dash or dot on the crankshaft gear. If your engine has a ball bearing, the mark would be located on the crankshaft counter-balance. It is important that the marks match, EXACTLY. One mark will be on the top of a tooth on the gear, the corresponding mark will be found on the bottom of a tooth on the other gear.
Posted on Oct 06, 2009
Testimonial: "just what i asked for precise and to the point thank you"
The tork on a chevy 350 motor connecting rods
The "TORQUE" setting is below
Bolts or Parts Lube or Sealer Torque to: 7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs. 7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs. 7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs. 3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs. Warning!!! If you are using ARP bolts, you MUST use
their specs. Click Here! 3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs. 11/32 Connecting Rod Bolt Engine Oil 35 ft-lbs.
Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs. Oil Pump Engine Oil 65 ft-lbs. Oil Pan Engine Oil 12 ft-lbs. Cam Sprocket (upper gear) Thread Locker 20 ft-lbs. Timing Cover Engine Oil 6 ft-lbs.
Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 30 ft-lbs. Valve Cover Engine Oil 3 ft-lbs. Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs. Spark Plugs No Lube or Sealer 20 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 60 ft-lbs. Clutch Pressure Plate Thread Locker 35 ft-lbs.
Centerbolt
(Harmonic Damper)
Engine Oil 60 ft-lbs.
Bellhousing
(Transmission to Block)
Engine Oil 25 ft-lbs.
Dec 02, 2016 | Cars & Trucks
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
NEED TORQUE SETTINGS FOR 18 HP MODEL 31H777-0297-E1. ROD BOLTS AND HEAD BOLTS. IS THERE A PATTERN TO TIGHTENING HEAD BOLDS
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Aug 16, 2010 | Briggs & Stratton Garden
310707 type 0137 in craftsman rider; won't crank fast enough to start most of the time.Battery, starter good. Ign. sw, solenoid,interlock switches test ok. Jumper battery connected to rider battery for...
worn cylinder rings. oil bypasses rings. try anew spark plug one heat range hotter, if that does not help , look at starter a little closer.have it rebuilt
Mar 26, 2010 | Garden
Garden Logo
323 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
