Question about Hotpoint WMA64 Front Load Washer
THE DOOR ON MY HOTPOINT WMA64 DOES NOT REGISTER AS BEING CLOSED
  • ross1rfc Oct 06, 2009
    Hi were do i find the sensor wire?
I thought my Hotpoint washing machine had completed it cycle i opened the washing machine to find it still full of water. I then realised the switch had tripped, I turned the electricity back on, to find the keyhole sign constantly flashing. I tried to change cycles to get rid of the water, but the keyhole sign still flashing.
Can anyone help?
Posted on Oct 30, 2009
    Scholar:
  • 43 Answers
The most common cause of this is the sensor wire inside has vibrated loose and is no longer making a connection to the switch. Those switches rarely fail. It's a very easy fix, only need a screwdriver. I would, however, use a small plastic ziptie to hold the wire to the switch.
Posted on Oct 06, 2009
2 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: Hotpoint Door Seal WMA64
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 15, 2009
My hotpoint washing machine wma64 will not spin
Dear Blaze,
Here is a link for a service manual Hotpoint WMA64 Installation And User Instructions Manual
The drum motor, its brushes, the belt, or idler arm roller, and the drum roller bearings can all be suspect. Here is a link that supports the statement Hotpoint Ultima Extra Wma64 Drum Not Turning E32 Fault Code Hotpoint...
Here is some conversation not relevant to your statement but maybe associated later on Faulty Hotpoint WMA64 DIYnot com DIY and Home Improvement .
I suggest when it is repaired to do a service wash to clear the drum of buildup.
Fare. Well.
Dec 28, 2014 | Hotpoint Washing Machines
I HAVE TO SLAM DOOR SEVERAL TIMES TO GET IT TO START
This means that the door switch is faulty or that the main controller board or connectors are loose or have a poor connection.
So the best way is to check the door switch, use a good degreasing spray like WD40 to clean tteh contacts, remove the connections of the board, clean spary and reset.
Make sure when the door is shut the switch contact is closed and contacting.
Sep 17, 2011 | Hotpoint WMA64 Front Load Washer
Could you tell me the load capacity to the hotpoint wma64 please
Maximum load 5.5Kg
Wash Load Examples:
Two examples
of maximum
wash loads for
different types
of fabric.
COTTON
2 Bath Towels
5 Shirts
6 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 5.5kg
SYNTHETIC
2 Children's
Dresses
4 Shirts
4 Blouses
1 pair of
Pyjamas
4 items of
Underwear
= 3kg
Jul 29, 2011 | Hotpoint WMA64 Front Load Washer
When i close the door the machine cuts out and trips all my other switches
hello it sound like the interlock switch could be earthing out or it's possible the motor could be earthing out aswell check all the wired connections to the washer make sure
regards
shaun
Jan 09, 2011 | Hotpoint WMA64 Front Load Washer
Hotpoint washing machine barrel not turning all other functions OK. Motor, belt drive and bushes look ok new curcuit board replaced any Ideas? Model wma64
could be motor not rotating under pressure. When you say brushes have you removed them from motor to check them, also check they slide in and out thier holders ok, as they may be sticking
Feb 11, 2010 | Hotpoint WMA64 Front Load Washer
Door lock light flashing and washer won't start.
door not locked properly, may need a little push.
Jan 19, 2010 | Hotpoint WMA64 Front Load Washer
WHERE IS THE FILTER
this sounds more like grease marks rather than sludgy marks,i bet you the bearrings have worn out,check this out by opening the door and the silver drum inside will have a knocking noise as you lift it up and down,when bearrings have worn out this causes a sludgy diposite,rgds,paul
Jul 07, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Door wont lock
to test if there is a fault on your interlock you can close the door now with your hand bang it on the front of the washer were the door hits the catch most cases if it faulty than the washer will start it will then need replacing only thing you can do if faulty m8
Sep 22, 2007 | Hotpoint WMA64 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
