Question about Gateway FPD1975W 19" LCD Monitor
Our computer monitor is fuzzy, all the text shakes up and down rapidly. What is there to do?
  • 35 Answers
Try changing the refresh rate--In windows go to display properties/settings till you find the refresh rate selection which will vary as 60Hz; 70Hz; etc. try different values to see if it helps. Had this problem myself but not as bad as you described. Changed from 60Hz to 70Hz and cured jitter problem. Good luck.
Posted on Oct 09, 2009
  • 34 Answers
Try reinstalling the driver, make sure correct power cord is being used, check power connections on surge protectore or outlet... if all is well and this continues... unfortunately your monitor may have cancer and is on its death bed. u have warranty? return options?
Posted on Oct 06, 2009
Fuzzy text
You need to test the DVI port and use the DVI-VGA adapter if your computer does not have a DVI port.
Dec 25, 2013 | Dell ST2210 21" Monitor
My monitor got bumped in a move and all of the text on the display is now fuzzy....any suggestions?
The picture board on your monitor is malfunctioning that is why the display is now fuzzy, This is a sign that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
Fuzzy text
Try adjusting the Font Smoothing effect in the display properties. Windows XP http://support.microsoft.com/kb/306527
Nov 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Screen Shakes on High Resolutions
your rate of refresh is too high, it's refreshing too fast, you need to lower the screen resolution. keep in mind, the tv resolution is much much smaller than a computer monitor. a computer monitor has much higher resolution. so Tv can only handle so much in resolution. if you need a better picture, it always the best to buy a monitor, not a tv for computer to get a good picture. if you have any more questions, let me know.
Oct 17, 2009 | Televison & Video
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
376 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
