Question about Western Digital Caviar WD1600BB 160 GB Hard Drive
Can wd 1600bb be replaced with alternative - Western Digital Caviar WD1600BB 160 GB Hard Drive
    Scholar:
  • 118 Answers
Generally your hard drive CAN be replaced with almost any other, just make sure you get the same type, as in IDE or SATA drive for a replacement.
Posted on Oct 07, 2009
WD-52725 Picture Quality Problem
sounds like a possible issue with the Optical light engine itself.
Nov 28, 2012 | Mitsubishi WD-52725 52". Rear Projection...
2006 ford tauras i replaced batterie,alternator,and belt i have a noise coming for the bottom pulley while i spray wd40 around the bottom pulley only the noise stops what makes this pulley go out and how...
First, if you have sprayed WD-40 on your belt, your belt has been wrecked and needs to be replaced again. WD-40 will only soak into the belt and CAUSE it to slip and make noise.
Then you need to check the alignment of all the belt pullies. The tensioner pullies on many Fords can wear and sit a little out of alignment and cause the belt to rub sideways against the other pullies. Replacing the belt tensioner usually fixes it.
Jul 09, 2011 | 2006 Ford Taurus
Noise coming from alternator belt pulley
never spray wd40 on your belts,if it gets on the pulley the alternator or power steering will slip and not work,
listen with an extension bar and pin point noise,if its a bearing in something or maybe just replace the belt for cracks.
Dec 25, 2009 | 2006 Ford Taurus
2001 Toyota 4runner Limited Alternator belt broke.
simple really 12mm wrench an socket and 14 mm wrench an socket. lossen alt bracket 14mm then tesioner 12mm slide back drop belt and reverse. unless condensioner belt in way then dro 12 mm bolts on shiled then back off 12mm bolts on condensioner pulley remove belt follow previous instructions
Nov 22, 2009 | 2001 Toyota 4Runner
2002 Chevy s10 electrical problems
Not to well versed on the S-10 electrical system but I would take a look at the voltage regulator.
It sounds like there is a malfunction that charges your battery sometimes but shorts out the alternator other times. Try having it tested or replace it
WD-40 will not do the trick for cleaning your terminals. WD-40 was developed during the 2nd WW to combat moisture in radio equipment in the South Pacific. WD stands for water displacement and the 40 is for formula #40. To clean the terminals you must disconnect them and use an abrasive such as emery cloth to remove the corrosion. They should be brite and shiny when you put them back together. I always cote mine wit dei-electric grease before re-assembly
Nov 20, 2009 | 2002 Chevrolet S-10
My 1990 Century has had troubles when the engine is wet, I put wd-40 on the spark plugs as I had read to do, but it won't turn over, I hear the clicking of the starter, but that's all. Is it the...
You probably have a dead battery. It could be due to a bad alternator, yes, but battery may need replaced. Put battery on charger overnight and see if it starts. Have battery tested, replace if needed.
Nov 05, 2009 | 1990 Buick Century
1995 Jeep Grand Cherokee squeaking and power steering
It very well could be the pawer steering pump. But to isolate the squeking sound, take that can of wd-40 and find the idler pully and tensior pully. Spray the bearing area of both pulleys. If your bearing in those pulleys are going bad then it will make that noise. If the wd-40 quits the noise at one of those tow pulleys then you know which one to replace. If its does not, then start looking to replace the powersteering pump. I take it you have checked the power steering fluid levels and they are ok?? Also, you stated that the noise started after you bought the alternator, then try a new alternator. It might of just been a faulty alternator. Happens all the time. One last inexpensive tip is replacing all belts with new. Belts get glazed over and dirty and cause noise too. One last question. Did you make sure the belts were tight enough? Just a little variance in the belt tension can make the difference.
Aug 07, 2009 | 1995 Jeep Grand Cherokee
What kind of case enclosure (3.5) should I buy?
Check out the review on the hard drive case we use in our shop at www.ccl-la.com We have been using these drive cases for a while and have had no complaints, and it works for both IDE and SATA.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 09, 2009 | Western Digital USB 2.0 External Enclosure...
Second Hard drive
it seems like it is not recognizing the hard drive, the error is coming from the cdrom/dvdrom. make sure that the hard drive is jumpered to slave,and the cd/dvdrom is put on the other ribbon cable set at master drive
Apr 09, 2008 | ASUS M2N-MX Motherboard
Mitsubishi WD-52525
By "honeycomb" do you mean it looks something like 96 colums with horizontal lines running across them, left to right, alternating in intensity from top to bottom and side to side?? If so that's a common failure of the FMT board Mitsubishi p/n# 930b924002 and a spendy little board it is... Average cost approximately $425.00 dollars plus shipping... https://www.vancebaldwin.com/
Another alternative is to have it rebuilt at PTS Electronics for about $350.00 dollars plus shipping. http://www.ptscorp.com/
Any qualified shop might use one of these alternatives or bench repair it instead. A lot would depend on the findings of their tests.
Good Luck!
And please don't kill the messenger...
Bill
Nov 25, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Western Digital Caviar WD1600BB 160 GB Hard Drive Logo
258 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
