Question about SuperMicro X5DAE Motherboard
Hi, my motherboard will go through all the pre-tests with no errors. CMOS config is fine. recognizes all hard drives and cd-roms. When it comes time to boot from disk, MB will not. goes to flashing cursor - no dos prompt
  • Vladimir Zavodny
    Vladimir Zavodny May 11, 2010
    Hi, can you reset the bios - just to be sure it is no weird settings? Try disconnecting the hard dives and all "unnecessary" pci cards, except video of course. Try to run a linux live cd. If it boots ok and runs ok, it may be a faulty system drive, or just bad master boot record.
  • dave836
    dave836 May 11, 2010
    Sounds like it cannot find the operating system. What operating system are you running and has it been running on this computer before?
    Genius:
  • 1,066 Answers
There will be no dos prompt on a machine with a newer version of windows. if you have wndows 2000 or later, you can use the windows disk to repair the boot sector.
Posted on Oct 09, 2009
  • 272 Answers
Try reinstalling Operating system.
comment here if need any other way to solve this or reinstalling does not solve the problem.
Posted on Oct 07, 2009
    Scholar:
  • 138 Answers
Try refreshing the connections of the HDD, and CD/DVD ROM drivers to the motherboard. Also check the jumper settings of the Drives. Hope this helps.
ASUS P4P800-MX stopped recognizing drives
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jun 28, 2012 | ASUS P4P800-MX Motherboard
I have a HP G60-519wm, pn vm083ua. It gave me an error of no bootable drive and hard disc failure. I replaced hard drive, purchased new recovery discs from HP, and downloaded a boot disc. It still gives me...
try to open the cmos setting by pressing the f10 key then check if the hard drive you installed has been detected, if you can see it, go to boot option then change the 1st boot device to cd-rom drive then the 2nd boot device will be your hard drive then click esc to save the setting put your recovery disk on the cd-rom drive then reboot the unit if ask press any to boot from cd rom just press a key or simple tap any key on the keyboard, then follow instruction.
Aug 03, 2011 | Computers & Internet
Bios not recognizing hard drive and cd rom. usb ports work
Hey I have the same problem, may have found a solution to this problem although im not 100% positive but read My post here in a reply to the same exact problem. Keep in touch with Me on this and maybe we can find a permanent solution
Feb 16, 2010 | Acer Aspire 5050-3371 Notebook
I had a HDD failure. I replaced the HDD with a WD1600AAJB HD. I am running win98se on this unit and had reinstalled win98 and some programs after the initial boot. I am now unable to boot and have been...
The most common cause of checksum errors in CMOS is a battery that is losing its power. You should pull the cmos battery and check its voltage with a volt meter. (It should read no less than 2.6 volts DC though 3.0 is recommended). Or just replace the cmos battery altogether. Viruses can also affect CMOS settings.
After checking the cmos voltage and or replacement of the cmos and while the system is powered down. Remove the system memory for about 1 minute. Doing this will remove any possible memory resident virus’s.
Download Western Digitals; Data Lifeguard Diagnostic for DOS (Floppy) or Data Lifeguard Diagnostic for DOS (CD)
WD's web site;
http://support.wdc.com/product/download.asp?modelno=WD1600AAJB&x=6&y=7
Use this software to setup you're hard disk drive.
You can also test the drive for errors and much more. Both of the above, floppy or CD are bootable and work in DOS mode. (Keep in mind all data will be erased). This is the best way to setup you’re hard disk drive before installing windows on it.
Cheers'
Mike
Feb 07, 2010 | Computers & Internet
Dell Dimension 8200 turns off in BIOS
If the dianostic lights A & D are yellow an IDE bus failure has occurred. Reseat the IDE cables at the motherboard and drive(s). If this does not resolve the issue you may need to contact Dell for a motherboard repair or replacement.
Mar 13, 2009 | Computers & Internet
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Please help... i am installing a new sata hard drive but it is not detected...
Please give us more information.
1. How old is your PC?
2. Size of your old & new hard drive.
3. CPU speed, motherboard brand & model.
If your motherboard unable to recognize the size of the new drive. then, you can find BIOS update for you motherboard.
Mar 18, 2008 | Intel Motherboard
Sata Config
go to bios settings, usually F2 on boot, then CMOS setup, check that it is there, and if not try to have the bios search/recognize it. Save settings and reboot.
Jan 29, 2008 | ASUS AI Lifestyle P5N32-E SLI...
SuperMicro X5DAE Motherboard Logo
127 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
