Question about HP Color LaserJet 2600n Printer
Won't let me print
I have the HP Color LaserJet 2550L. I pulled out the drum and replaced with same. It goes through the start up routine, checks the cartriges for 30 sec or so. and stops on the orange triangle and blinks.
HELP!! PLEASE!!
Christmas calendars to put out. :o)
Thank you
Randy Osborne
  • 82 Answers
Check for some piece of paper or other jam inside, if only triangle blinks...
Posted on Jan 05, 2008
HP Color LaserJet 2550L. Missing colors
The main circuit board is faulty and needs to be replaced.
Feb 27, 2014 | HP LaserJet 2550L Printer
Is my 2550L toast????.
The HP 2550 does take a while to print. It calibrates through all the cartridges & then you'll see your print soon after. You probably need your printer professionally cleaned out with a toner vacuum, the squeaking could be coming from the drum or a pick up roller.
Jul 02, 2009 | HP LaserJet 2550L Printer
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
HP color laser 2550l prints only yellow
Are you sure that none of the other colours are empty? If they are then this could be the problem
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
2550L won't print
Check the HP forums for this problem, there may be some kind of 'secret' reset routine that must be done to clear the error from memory. It could also be that whatever element controls the power to the fuser failed.
Curious: did you check the original fuser to verify that it had failed?  Since the problem is still there, the first fuser may not be bad at all. They are in essence a resistive heater that could be checked for continuity with any multimeter.
Sep 22, 2008 | HP LaserJet 2550L Printer
select color settings in the printer properties on your pc
Aug 06, 2008 | HP LaserJet 2550L Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
HP Color LaserJet 2600n Printer Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
