Question about Maytag Neptune MAH7500WH Front Load Washer
Speedindication Error I get a error message that say: Speed Indication Error. Is thia a part that needs to be replaced?
  • Anonymous Jan 03, 2008
    I am receiving the same problem with my neptune washer and the repair man said it is more than likely the control board when I spoke to him over the phone.  From what I have seen online this is a major problem with these machines.  Repair man also stated that it would cost around $450 to $500 to repair the machine with parts and labor.  I think it will be replaced and not fixed!
  • 196 Answers
Yes, The motor and motor control board are not talking to each other. The motor has a built-in tach that signals the board as to its' position and speed. One of the two is faulty. This is an expensive repair. Parts will cost between $225 and 325 depending on where you are. Make sure the repair tech has a good reputation before proceding or do it yourself.
Posted on Jan 15, 2008
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Speedindication error on MAH7500AWW
These machines are "known" to have computer board problems. When replacing the comp. board it is best to replace the motor as well because you can buy them in a kit toghter. (part# 22004473) cost around $150.00 ... GOODLUCK
Dec 23, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
I keep getting a speed error message when I start the belt
Precor Error LS, Speed Sensor Signal Missing Probable Cause 1. Intermittent or open connection of the speed sensor (reed switch) wiring.
2. Reed switch is defective or has intermittent connection.
3. Drive motor brushes are bad.
4. Lower PCA is bad.
Corrective Action
  1. Inspect the speed sensor (reed switch) wiring for damage or poor connection to the lower PCA. Replace damaged wiring or reset connection as necessary.
  2. Using an ohm meter, test the reed switch while rotating the drive pulley. The reed switch will close when the magnet passes in front of it.
  3. Inspect the drive motor brushes and replace if necessary.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
Precor Error Code LS
Dec 08, 2014 | Precor Exercise & Fitness
Speed sensor L5
follow this steps and fix it. God bless you
SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH belt movement
This is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor. Refer to the flowchart on page
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board.
Oct 21, 2013 | Landice Exercise & Fitness
PRINTER mp145 is displaying E2 error message saying that no paper, how ever im not going to use printer, instead i want to use scanner but with E2 error message i cannot scan so pls give me one solution.
Do you mean E,2,2 indication? It means Carriage error.
Replace the following parts in the given oder
Timing **** strip film Logic board ***'y Carriage motor (Main unit) Carriage unit (Main unit)
May 15, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Error 99 message keeps popping up
I just read that the error 99 problem is a shutter failure and the shutter will have to be fixed. The cost is about $180.
ERR99 (error 99) is an indication that there is a communication problem in the camera. It is most often an indication that the shutter needs to be replaced, but it can be the result of other problems. All digital cameras occasionally need to have the shutters replaced. In the days of film cameras, it was rare to wear out a shutter because the cost of film and developing limited the number of times the shutter was cycled. With all those ones and zeros being considered "free" in digital cameras, it is not uncommon to take several hundred or more photos in a day. Even with a live-expectancy of 50.000 to 100,000 cycles, the shutters in digital cameras do reach the end of their life and need to be replaced.
Shutter replacement (usually associated with error code "99"):
  • Replacing the shutter on the Digital Rebel series requires more disassembly than most other repairs.
  • The estimate for shutter replacement is $180 on all EOS Digital Rebel models (depending upon the overall condition of the camera).
  • ERR99 error codes are related to shutter or mirror operation and are usually associated with a defective shutter. Cameras that have had heavy use may have shutters that have reached life expectancy and need to be replaced.
May 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Speed indication error
Jan 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
99 BMW M5
How many miles your car is?
check your fuel filter, maybe it is too dirty.
hope thias can help
Jun 22, 2008 | 1999 BMW M5
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Maytag Neptune MAH7500WH Front Load Washer Logo
392 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
