T-Mobile Wing™ Smartphone Logo
Posted on Oct 06, 2009
I can't connect internet to china made iphone, can you provide me settings ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
635
Points
I can conect interne on chineese iphones
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
To connect to internet via phone
try using the wiffi go to settings turn it on and connect to the internet and open safari on your iphone ,or go to your local service provider and ask for the internet settings or ask about internet plans and deals
1helpful
2answers
Internet connection
Hi, check your internet settings.Make sure the connections activated.You can also get the settings from your service provider.They'll need a few details including your phone model before sending you the settings. Hope this helps.Thanks!
Jan 07, 2012 • Cell Phones
2answers
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Why yahoo down in china today
The problem is most probably with your internet provider, having trouble connecting to yahoo china. You can use Open DNS as nameservers, tho. This gives you a better chance connecting to yahoo china and other websites you're having trouble connecting. Go to your network connection settings and on the TCP/IP, instead of using obtained DNS server, use the following:
208.67.222.222
208.67.220.220
Should you need further assistance, please let me know.
May 16, 2010 • Yahoo Mail
Is it possible to get the internet working on a china iphone. thanks bernie
The answer to your question is, Yes! Here is a link on how to set up a P-168 China iPhone clone for T-Mobile. (NOTE!) This settings are old and may have been changed by now by T-Mobile. Call T-Mobile and ask for tech support to get the current settings. Do the same if you have AT&T as your provider.
Click here:
http://yzcompany.com/ebay/P168+-Setting-for-T-Mobile.htm
Just a note: I programmed the internet settings for T-mobile into a cell phone watch from China about a year ago and it worked great. So it can be done.
I have china mobile model. n82i .internet problem
download the internet setting provided by your network provider also download the setting for nokia handsets those are the only handset model of nokia recognized by your network service provider.
Connect nokia 5310 china phone to internet...
If it's from China, a clon, not original Nokia, try to set up the Wap and GPRS. You need to configure the set up your self with yours wireless provider's information.
2answers
How to make internet settings on china mobile..?
i) in the case of branded mobile(such as nokia, samsung, lg, .....), u can get internet setting to ur mobile by sending a message from ur mobile,  but this is not the caseof china mobile
ii) in case of china mobile u have to take mobile to ur nearest service provider center(fore eg: vodafone mobile store in case of vodafone service provider) and he will make some settings in ur mobile(internet settings) and activate the internet manually(otherwise insist him activate internet there itself)..
Thank you
M. Sridhar
Top T-Mobile Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
