This is more for information question. Dose Mitsubishi have a DLP TV that dose not use a color wheel and lamp where you can get 3D?
    President:
  • 788 Answers
Yes, Mitsubishi did make a DLP that did not use a color wheel, but I am not sure if they still make it. It would be in the Diamond series and it uses 3 image units. I believe this was a professional set and was very expensive. You may have to ask around at you local electronics store to see if Mits still make this set.
I hope that this helps.
asnowman
Posted on Oct 10, 2009
What is wrong with Mitsubishi tv Model WD:82738? I just replaced the lamp and it is making a sound like a bearing rubbing and the picture is flickering.
It sounds like your color wheel is going out. Here is the part#. If you do not feel cofortable with this type of repair, please have a servicer do it for you. Good luck to you.
May 23, 2016 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
My mitsubishi wd82738 starts normally green light flashes and then stays on,i get sound and blurred bars that are barely visible
Probably a lamp problem. They aren't very expensive and relatively easy to replace. If not the lamp, possibly the color wheel. If it makes a high pitched sound from time to time, it's definitely the color wheel. Good luck
Aug 26, 2014 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
I have a Mitsubishi WD65738. The picture stopped working and still had sound. I replaced the lamp and cartridge and now it doesn't turn on and i just get a flashing yellow light. What can I do?
If you replace the lamp you need and got sound no picture is your color wheel. Make sure the cover wherew the lamp goes is close completly other wise it would not work.
Thank you
Nov 22, 2013 | Mitsubishi WD-65738 Medallion 65 3D DLP...
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
I trayed to calibrate the colored cross hairs and the blue lamp dose not indecate cross hairs it is just a splater.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Wd 62327
Jul 31, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
