Question about JVC HX-Z1 CD Shelf System
I have a problem, my system not turn on. The system don't supply 5V. What can i do?
  • 70 Answers
You may have had a power surge that took out the fuse or damaged the standby power supply.Look for burnt or damged parts and replace them or service the SB power system.
Posted on Oct 06, 2009
Prolink h5201
No. You must use a 5V ac adapter/power supply.
But are you certain that you need 5V ac to power your modem ? Where are you located Jane ?
22.April.2014
Feb 16, 2014 | Computers & Internet
Name of wire based on color coding wire
Special (only on the ATX conector)
-Green is PSon(put a wire between green and black to turn the power on)
-Gray is PWRGOOD
-White is -5V(optional)
-Blue is -12V
-Purple is 5VSB(Always on when the PSU is plugged on)
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
-Black is Ground (0V)
Dec 20, 2012 | Lite On LiteOn 204Watt PA-4022-6B Power...
Wire name based on color coding wire
-Gray is PWRGOOD
-Blue is -12V
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
Dec 20, 2012 | Lite On (PS-5101-2B) (ps51012b) 145-Watt...
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
Trying to find wich two or more wires from wiring harness turn on power supply for a compaq presario 7594
In ATX PC power supplies, here is the wiring scheme:
Green: PS-ON (+5V)
Gray: PWR OK (+5V)
Purple: +5VSB
Blue: -12V
White: -5V
Orange: +3.3V
Red: +5V
Yellow: +12V
Black: Ground (AKA Common)
Use a paper clip to connect the GREEN wire and a BLACK wire. There should be a black one right next to the green. This is how I test PSUs before and after I repair them. Now it should be running, assuming there are no internal problems.
You can also connect the GRAY to ground with an LED. Not necessary, but I like to do it ;)
Nov 24, 2009 | Computers & Internet
Need to know "no bus" indicator light on instrument panel....
"No Bus" means the data cable going to the (PCM) computer is unplugged, or the PCM has failed and not able to read the information it is being given.
Sometimes just jiggling the PCM causes the ODO "NO BUS" to come on.
Sometimes a bad crank or cam sensor can cause this as well.
Here is the OFFICIAL checklist for the "NO BUS" condition....
Vehicle: 1998 - 1999 Dodge Durango 3.9L
2000 - 2001 Dodge Durango 4.7L
1998 - 2000 Dodge Durango 5.2L
1998 - 2001 Dodge Durango 5.9L
Symptom: Engine will not start. Gauges are inoperative. No BUS message displayed on odometer.
System: Body/Chassis Electrical, Emissions/PCM/Fuel, Engine Electrical
Codes: N/A
Problem 1 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Crankshaft Position (CKP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) sensor. If 5v is not present, unplug the Crankshaft Position (CKP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CKP sensor.
Problem 2 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Camshaft Position (CMP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the Camshaft Position (CMP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CMP sensor.
Problem 3 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Manifold Absolute Pressure (MAP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5v power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the MAP sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the MAP sensor.
Problem 4 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Throttle Position Sensor (TPS).
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5 volt power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the TPS. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the TPS.
Problem 5 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted wire.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the throttle position sensor (TPS) or manifold absolute pressure (MAP) sensor. If 5v is not present, unplug all sensors that are connected to the 5v power supply and disconnect the PCM. Check if either 5v power supply circuit is shorted to ground using a DVOM. If the circuit is found to be shorted to ground, repair the wire and the cause of the short.
Problem 6 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Governor Pressure Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the large round connector on the driver's side of the transmission. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, remove the transmission pan and check for shorted wiring inside the transmission. If the wiring is OK, replace the Governor Pressure Sensor.
Many times the PCM simply overheats - and changing it will stop the problem.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | 1999 Dodge Durango
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
ASUS P5GL-MX performance
Install new power system!
Thanks,]
Melcom Smit
Oct 04, 2008 | Computers & Internet
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
JVC HX-Z1 CD Shelf System Logo
96 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
