I want to set pin before dialing mobile number from panasonic KX-TDA 200
Hello here's how to change the name of your extensions. (All programming has to be done from the phone plugged in to Jack on the phone system) Press: Program -you will see: pits-pgm no? Press: * then # -you will see: password Enter: 1234 (that's the default) You will see: says-pgm no? Here's where you enter the code for what you want to change. People sometimes use 004 and scroll thru all of them. We are going to use 604 to change extension name. You will see: extension name Hit down arrow until you see the name you want to change. Then start typing the name by using the number pad. After you are done hit "store" Now go to that phone and pick up and put down the receiver to clear the old name.
I Cant seem to get this function to work...PLEASE help!
If by ID you mean name, it's done in SYSTEM programming. That location changes by system model number, but usually it's in either 004 or 604.
If you mean something else, please comment back.
Carl
What system?
