Question about Sampo PME-50X7 50 in. HD-Ready Plasma Television
Hi, remote not working and unable to change channels using tv buttons. other buttons on tv - volume etc are working fine
  • 3,640 Answers
If your remote is for cable, then you have to push the cable button, then change channels. volume will work only on tv mode.
Posted on Oct 06, 2009
MY small kitchen tv will not change channels.Everything else is working fine, volume, color, etc. Can you help me?
Depends on make and model. Does the remote control work if it has one? Can you change channels with the TV buttons etc.
Aug 29, 2017 | Televison & Video
JVC tv stuck one channe
I would either call JVC to see if known issue or to inquire if set has a lockout feature that kills remote and all button features----other possible reason in main board with all micro functions has a problem.
Aug 27, 2012 | JVC LT-32P679 32 in. LCD TV
Everytime I change a channel on my LCD Tv Hi Sense 32
If your using front button to change channel then try to use remote..
If on the remote is fine then the button board of your TV got faulty usually it cause bad contacts of button (vol+,vol-) so that if you press any button the volume button activated due to auto contact..
You can replace the button or replace new button board assembly..
Dec 24, 2011 | Televison & Video
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Change from TV mode to AV mode for a Hitachi C28W4110SN
There should be buttons somewhere on the TV itself to switch input modes. Look around where the power button is located and see if there is a menu button you can access. Then use channel up/down and volume up/down to scroll thru modes to find input
Hope this helps
TankMurdock
Apr 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Sampo PME-50X7 50 in. HD-Ready Plasma Television Logo
162 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
