Question about Nextar MA797-20 MP3 Player
The player is fully charged but does not sync to my computer. It keeps doing the blender charging symbol. I've had it charging for 7 hours
    President:
  • 803 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturers website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Nov 03, 2009
When I try to turn on the MP3 (Philips GoGear Mix) I see a symbol of a battery and then it shuts down. When I plug the MP3 to the computer it shows it is fully charged. What shell I do? Thanks
I have had a GoGear for a while and those things have horrible firmware and are very fragile. I have experienced the same issue myself, so I suggest leaving it plugged in for several hours no matter what the screen says to try and let it charge. It should charge up. If not, try charging via a usb wall charger, which should allow usage of the player while it charges.
Jun 01, 2011 | Philips GOGEAR SA6045 MP3 Player
I ahve a no name mpe player and try to sart it and it just comes up with the loading symbol but will not go any further
Hi there
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Sep 16, 2010 | Jwin MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
I have charged my sony e readerPRS - 505. However
Connect the Reader to the Computer using the supplied USB cable and check whether it is charging,. If it's charging , then keep it connected from at least 4 hour to get it fully charged. If its fully charged, perform a soft reset. To soft reset, just press the RESET button. After soft6 resetting charge it for at least 4 hours., That should resolve the issue. All the best! !
Nov 30, 2009 | Sony E-reader Portable E-book MP3 Player
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Zen Vision M battery not charging
The problem was partially solved in that I put my old battery back in and at least it charged properly. I did receive a new battery from BatteryMill and I fitted it and left it charging for 5 hours. However, when I unplugged it to see if it had charged at all it did the low battery thing and then when I tried to recharge it the battery fully charged symbol ame up. I suspect that had I left the new battery charging for say 24 hours it might have charged fully. However, I have decided to send my batteries back and get a refund. The problem must be something to do with a battery memory problem.
Jul 31, 2008 | Creative Labs ZEN Vision:M Digital Media...
Symbol RF MC9060S - Internal Battery is dead
You have to first charge the backup battery, for charging insert a fully charged main battery into the MC906x. Then the backup battery will starts charging leave it there for one day. if that message is still coming then the problem is with the backup battery and u have to replce it
Jul 06, 2007 | Laser Symbol Technologies MC9060S Mobile...
Nextar MA797-20  MP3 Player Logo
291 people viewed this question
Top Nextar Audio Players & Recorders Experts
lolthepcman
ray gallant
Paul Chapman
Paul Chapman
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
