Question about Whirlpool MH2155XP Microwave Oven
Microwave comes on but will not heat
Microwave comes on but will not get hot
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Why won't heat on inside although hot air comes out on side of microwave?
Oven cleaner should not be used on a microwave oven.
May 02, 2015 | Microwave Ovens
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
I have a model #401-80089700. The inside wall next to the controls will get hot and the microwave will shut off. after it cools, the display comes back on and it will work until it get hot again. It
all units have a thermal fuse that stops operation when case over heats . try replacing the thermal fuse could be out of tolerance.. looking for an obstruction in the high voltage radiation ducting that could be obstructing the flow of high voltage radiation , or the defuser belt or motor is no good or slipping, also the cooling fan obstructed or failed. .. all above to be handled by a master or journey man teck. or tv repairman. A professional not an novice.
Jan 21, 2015 | In Microwave Ovens
Cuts off when gets too hot
inside your microwave is a heat censor, if it cuts the microwave off then its to hot for safty have a good look round the back of it to check that the air vents are all clear and that a good air supply can get all around it when its cooking food,,, iv seen so many microwaves tucked away into a small place, and they will all cut out when they get to hot,,,1100 watts gets very hot too!
Jun 06, 2010 | GE JES1142SJ Microwave Oven
It quits heating after a couple minutes and sounds
replace the fan otherwise your microwave cell wil burn out, the safety comes on because the cell become to hot. no colling of microwave cell.
Feb 15, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
No heating or power to microwave oven
You have a fuse in the back that's problem is blown
Mar 13, 2009 | Microwave Ovens
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Whirlpool MH2155XP Microwave Oven Logo
125 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
