Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Bissell I inherited the Bissell Model 790 Steam Vac. No solution will come out. Apparently it's clogged somewhere as the previous owner appeared to have used it to vacumn up a powdered carpet cleaner. How do I resolve this problem as the machine is barely used and I would like to salvage it. Thank you
  • 1,673 Answers
Check the belts first, if ok, does water squirt out of the hose nozzzle, if it does then the heate in the handle asm. is clogged where the tubes hook up to it. If no water squirts out, the the pump isn't working. Pull the top cover off, check all tubes to make sure there is no clog. Make sure the tubes are routed right so as not pinch one, also make sure the piston is mounted on the smart mix knob. and the knob is in the water setting before putting the cover back on. The cap for the flow indictor is leaking are or screwed on too tight. The seal at the bottom of the tank is not on the tank and is missing or sitting in the hole where the water goes.
Posted on Jan 17, 2008
Bissell steam mop water filter will not work even though it's new
Either it is installed incorrectly or there may be a leak or clog before or after the filter. Double check your connections and check for clogs.
Calcium Water Filter for Bissell Steam Mop Cleaners
GoodVac com
Feb 26, 2015 | Bissell Vacuums
My problem is that dust is shooting out of my powerforce bagless bissell. I pulled and detached the filters, hitting them againt my front steps which is cement, burshing my hand across the filter . Yes...
It could be a clog somewhere, a air leak somewhere and/or clogged filters. Cleaning filters does not necessarily mean they are not clogged. They should still be replaced quite frequently.
Sep 06, 2017 | Bissell 6594 PowerForce Bagless Upright...
Where can I find a free manual for Bissell 1699-K steam vac?
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell PROHEAT PRO TECH 1699 Repair Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jan 22, 2011 | Bissell 1699 ProHeat Clear View Upright...
Hoover steamvac won't spray water/cleaning solution
Clogging of the pump that sprays water/cleaning solution is very common in Hoover and Bissell Steam Vacs. Try running a cycle of 1part vinegar or CLR to 3 parts warm, distilled water through the vacuum pumps. The heads get clogged with soap and the water pumps get clogged at the opening of the flash heater due to minerals in hard water. If you want to extend the life of your steam vac, don't use the heater unless you are using distilled water. This can get expensive, so I recommend not using the heater.
Sep 11, 2009 | Hoover F7431-900 SteamVac Vacuum
I need a manual
Generic problem for all Vacuums
I need a manual
Posted by mbeach38 on May 01, 2008
I need a manual
I’m sorry but you need to supply us with @ least the brand name and model # of the vacuum in order to get the owner’s manual from the factory or manufacturer, feel free to contact your local vac dealer to see if they have a phone # to the manufacturer for your owner’s manual. Here is an example of a manufacturer’s website or phone # ---
Example: Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Hoover F6030-900 SteamVac WidePath Wet/Dry...
On my bissell shampooer, model 7901-b i have no suction
On my Bissell shampooer, model
On my Bissell shampooer, model 7901-b i have no suction
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If you have no suction, you could have a base seal in the recovery tank, there could be a clog or blockage, or check the clear tubes to see the they are crimped or pinched so that the vac is not getting any air, or start from the bottom and work your way up to where you do get suction and you should find the problem, a lot of times it is a gasket or the recovery tank is not on there securely or you may have a broken part that needs replacement. So feel free to check with the local vacuum cleaner dealer in your area in the yellow pages under vacuums, check the trouble shooting section to your owner’s manual or call the factory or check the website and maybe down load or have them mail out a owner’s manual. By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Apr 22, 2008 | Vacuums
Need small hose and connector parts for a bissell steam vac. model 1690
Sorry but Bissell has obsoleted this model and all of its parts. About all you can do is call around and see if some one would happen to still have what you want in stock. Might be wiser to buy new.
User's Manual
if you go to you can get one there
Dec 15, 2007 | Vacuums
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
71 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
