Question about KitchenAid KUDI01TBK Dishwasher
The rubber clip which holds the upper spray arm has broken
  • 120 Answers
OK, well, the only solution is to go to your local parts place for appliances and get a new clip and install.
Posted on Oct 06, 2009
Upper arm of HJA 8362 keeps falling off. Could there be a part missing/broken?
yes - the clip that holds the arm on is probably broken off or weak. Order a new spray arm and spray arm support tube - a new wash basket will probably come with these parts on - but check first as some don't.
Jan 31, 2018 | Dishwashers
Upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Feb 04, 2010 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
NO WATER COMES OUT OF UPPER WASH ARMS
This is usually because of food items inside the arms.
Undo the top arm (clips or large screw) - and back-wash the arm through the spray holes..
This usually solves the problem.
Sometimes the clips wear that hold the arms on - if this is the case - buy a replacement spray arm.
Jun 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Upper spray arm detached
The upper arm clips onto the upper drawer not onto the nozzles!
Jun 21, 2009 | Siemens SE24A230 ExtraKlasse Built-In...
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
Jan 10, 2008 | Dishwashers
KitchenAid KUDI01TBK Dishwasher Logo
55 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
