Question about Toshiba Satellite U305-S2804 Laptop
Laptop will not come on. Is not operating on AC power.
  • 408 Answers
Either the ac adapter may be bad or the power jack it plugs into is not working.
Posted on Oct 10, 2009
Won't charge
Not really enough info here but I'm assuming you have a laptop that won't charge?
If the laptop runs while plugged into the AC power adapter but will not charge the battery, the battery will need to be replaced.
If the laptop will not run with AC adapter AND it won't charge you should test the AC adapter to confirm operation. It may be faulty. If it's not you likely have a bad system board on the laptop and should replace the laptop.
Microcenter.com has very good refurbished laptop deals that may suit your needs.
Feb 06, 2016 | Computers & Internet
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
It hang, i can't turn it off
Forcely shutdown the laptop by pressing the power button 5secs.Unplug the ac adapter (charger), remove the battery(located on the bottom) and without the power sources (w/o battery and ac adapter), hold down na power button 10 secs. Put the power sources back and turn ON the laptop.
Mar 01, 2011 | Samsung Computers & Internet
I have a Dell Latitude D800. I want to run it on AC power. Do I have to take the battery pack out of it before I ru it on AC power?
Hello Paula, Hi Never remove the battery out when powering with AC, your Dell will get busted, run ac with the battery. The AC power produces a voltage above the normal operating voltage of the Dell, the over voltage is for charging the battery and powering the DELL, if you remove the battery, the over voltage will bust the laptop in seconds. So operate the laptop with AC and battery.
Feb 11, 2011 | Computers & Internet
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
My laptop amilo m-6100 wont start up
although I never tried it, I dont think you can operate a laptop with no battery, even when its connected to AC.
Jan 02, 2008 | Fujitsu AMILO M-6100 Notebook
Toshiba Satellite U305-S2804 Laptop Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
