Question about D-Link DIR-655 Wireless Router
How to reset DLink DIR 655 router - D-Link DIR-655 Wireless Router
  • 134 Answers
Press the reset button in the backside of the router.
Posted on Oct 06, 2009
  • Siju Doniston
    Siju Doniston Oct 06, 2009
    You can do it from the web interface also .
    Login to the router with default Iphttp://192.168.0.1 with admin username (password is empty by defualt)
    GO to Tools menu, System settings and click Restore all settings to the factory defaults.
    Thanks
    Siju
    Master:
  • 368 Answers
For setting up your resetting d-link router you have to follow these steps..
1. open your browser and type 192.168.1.0 and type user name and password
2.go to wireless settings and setup ssid ( network name ) and password
3. than click save and apply for more technical help you may can contact d-link Tech Support
i hope this will help you thanks
Posted on Nov 26, 2014
5 Suggested Answers
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
rtrahan
  • 741 Answers
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Posted on May 03, 2009
mastersaintx
  • 928 Answers
SOURCE: Setup DIR-655 w/ Westell 6100 USB DSL Modem
First check if your computer can get on the modem with an Ethernet ( This is to find out if your router will work with your modem) If you cannot get on give your ISP a call to have them configure the modem for Ethernet connection. If you do get on then connect the router to the modem and your computer to the router. You can run the CD for the router or do the connection manually.
Posted on Jul 27, 2008
govinda123
  • 2263 Answers
SOURCE: i lost my setup cd for my dlink dir-655 wireless
You can set up your router manually, without the
CD.
Make sure that your computer is able to go online
directly through the modem.
If your computer is able to go online through the
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
Posted on Mar 17, 2010
Dlink dir-655
ftp://ftp.dlink.com/Gateway/dir655/Apps/RouterSetup_dir655_410.exe
Feb 13, 2014 | D-Link Xtreme N DIR-655 Wireless Router
I lost my password
Take look at the following link. This will reset your 655 to the factory defaults (including the password).
NOTE: You will lose any settings you have made, and will have to redo them.
http://www.dlink.cc/d-link-router/dir-655-forget-password-and-how-to-reset-it-back-to-the-factory-default-settings.html
Sep 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Lost dlink dir 655 password
Default user is Admin and default password is blank. (Don't type anything)
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults. To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
From: http://www.scribd.com/doc/6254595/DLink-Dir655-Manual-Wireless-N-Router
May 29, 2011 | D-Link Xtreme N DIR-655 Wireless Router
D-link DIR 655 owner's Manual
Look on router ID plate for REVISION.
Owner Manual Links:
For DIR-655: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655
For DIR-655 REV. B: http://www.dlink.com/products/?tab=3&pid=DIR-655&rev=DIR-655_revB
Thanks for choosing FixYa, If you find this helpful please vote and comment.
Oct 11, 2010 | Computers & Internet
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can't connect to my K-jam to my new DLink DIR-655 wifi router
Can't connect to my K-jam to my new DLink DIR-655...
Mar 11, 2009 | i-mate K-JAM Cellular Phone
D-Link DIR-655 Wireless Router Logo
16,970 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
