Question about Canon Office Equipment & Supplies
Canon pixma ip1980 service error 6000.. it flashes 3 flash...indicates paper jam but there's no paper on tray... pls help? What's wrong with my printer?
    New Friend:
  • 58 Answers
You need to open the printer. it has sensors around it. the one that you need to check is in the left side when you are facing the printer. the one that is sensing the graduated circular part. Remove the left cover on the side. then remove the sensor with a philip screw driver and clean it. then place it back and turn your printer on. I hope to be of help to you. Let me know if this works. I did it on mine.
Posted on Aug 13, 2010
  • mj_torres Jun 22, 2013
    i already tried ur solution but the problem wont solve,i had the same problem,pls help?
  • 117 Answers
Your canon pixma paper jam open the printer caling
Posted on Oct 07, 2009
3 Suggested Answers
SOURCE: canon pixma ip1980 service error 6000
the ink absorber is full
Posted on May 12, 2010
pineworks
  • 4041 Answers
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
How can I fix error 6000
Hi there
You don\'t mention anything about "blinking lights". This can help with diagnosis and correction. Please ind below some recommendations:-
This is a line feed error. It also should be flashing 3 times for this error on the on/off button.
Solution 1:
  • Verify that the paper tray is correctly set.
  • If any object is placed in front of the machine, remove it.
Solution 2:
  • Search for any small pieces of paper in the printer, or a tiny object.
Solution 3:
  • Power off the printer
  • Wait 30 seconds
  • Power on.
Solution 4: one of these parts could be faulty:
  • Timing sensor unit QM2-2683
  • Timing slit disk film QC1-6229
  • Feed roller ass\'y QL2-0925
  • Platten unit QM2-2923
  • Logic board ass\'y QM2-3078
  • Paper feed motor QK1-1502
My preference for sorting this problem would be number 2 if you experienced a paper jam prior to the problem.
Hope this helps.
Aug 27, 2014 | Canon Pixma MX432 Wireless All-In-One...
Orange flashing 3 times
This is a paper jam error. check for any paper jammed in the printer, switch it off and open all trays, sheet feeders, duplex unit to check for any paper. if paper was jammed previously and was torn, there might be a piece of paper still stuck in it.
hope this helps!
tom
Jul 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
Hi there
1. Turn On iP1980
Feb 07, 2010 | Office Equipment & Supplies
My PIXMA MP780 is still flashing check the printer then press ok - an error msge ##357 keeps coming up. what does this mean pls?
This is an error in the position of the paper feed unit.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Look in the sheet feeder too. If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Oct 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
3,207 people viewed this question
old marine
old marine
