Question about Kicker KX550.3 Car Audio Amplifier
Power to amp
Amp is not powering up and external fuses are good,burnt smell, use to work.Where can i have it serviced?
Thanks,
David
  • Anonymous Mar 24, 2014
    amp does not get hot the protection light does not come on it does not smell burnt fuses do not blow
  • 631 Answers
It sounds like the power supply has failed (burnt smell). Any local shop that repairs car audio should be able to repair it. If you don't know which shops repair car audio, call the local car audio dealers and ask them who they send their amps to for service.
Posted on Dec 23, 2007
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
I have a 1600 watt boss chaos amp it has power no sound rca jack good fuzes are good no burnt smell every thing is good just dosent have any sound
You need to check the 2 sets of fuses on the face of the unit.
Try removing the fuses and resetting them.
Power hookup is 12+, remote power on and negative.
Apr 26, 2014 | Car Audio & Video
Audio fonics amp ADF-2845
you dont have enough power for it. sell if for parts and buy a smaller amp and second battery.
Sep 20, 2013 | Audiofonics Car Audio & Video
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
My orion 6004 amp was connected, but it didn't turn on, so i was going to disconnect it and smoke came out from wire connections, i opened and i didn't find a solution Can you help me with it?
you had a short circuit.... you need to check the fuse of your amp if it is blown then replace it.. otherwise replace the cable if it is burnt and check your amp carefully
Aug 01, 2010 | Orion Car Audio & Video
PIONEER DEH-P86DHR NO SOUND!!
With these units, the internal amplifier is an IC that fails sometimes. It can leave the rest of the unit working ok, bit will have no audio. There may be audio from the line level RCA's but not from the speaker outs. Smell the back of the unit to see if it smells burnt. Most of the time it will, but not always. The IC is usually something like a PAL007a or similar. If you are good at soldering, you can order the part, and change it yourself. If not, you will need to seek a technician to replace the part. You may also try an external amplifier and RCA's instead of fixing the IC.
Jun 15, 2009 | Pioneer DEH-P86DHR
Purchased 12-26-2001. Stopped drying suddenly. Breaker is good. Interior light comes on and off with door switch. Can hear timer run when start is pushed. drum won't turn and no heat. David
Please use the "continue with this expert" option and reply with the manufacturer and model # so I can be of assistance to you.
Thanks!! :D
Jun 02, 2009 | Dryers
NO POWER
Try unplugging it from the wall for at least a couple of minutes.
Then plug it in and turn it on, listening for and looking for any signs of life.
Still nothing? Does the power point work with other appliance?
Thhen it looks like your amp has died and will need to be sent to a service location. Sorry, nothing further you can do.
And I am not trying to drum up business, I am in Australia and don't service them for a living.
Good luck, I know how it feels when your amp dies.
Apr 26, 2009 | Audio Players & Recorders
Kicker KX550.3 Car Audio Amplifier Logo
75 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
