Question about HP DeskJet 932c InkJet Printer
Cannot get to print in color. everything is black
    President:
  • 1,653 Answers
Print out a test print to see what comes out. If the printer is printing the colour blocks then the printer should be OK. If not then check the colour inks to make sure they are OK. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until the inks are printing OK then run an alignment test and adjust as necessary. Next check the settings of the print driver to make sure that you have not defaulted to Black & White or Greyscale printing only. Also check the printer to make sure that the setup is OK and no defaults to Black & White / Greyscale printing have been set. If all this is OK then the most likely culprits will be the interface lead to the PC / Mac. Check that this is inserted and secured correctly at each end and is not damaged. If this is OK then uninstall the printer driver and download and install the latest printer driver from HP support at the following link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=61236&lc=en&cc=uk&dlc=en&lang=en&cc=uk
Simply choose your operating system to proceed.
Once installed reboot the PC / Mac and all should be OK.
Posted on Oct 06, 2009
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
Can i print in black if my printer has run out of coloured ink?
Hi judysimeon
Goto the printer settings page and change the settings to print in black . Normally it is set for color - when color and black will print - You will find the question Print in Color Or Black Each has a check box. Check the box for black. With this setting, everything will print in black including the color text and graphics.
Most printers let you do this. However, some printers keep telling you to replace the color cartridge.
Hope this will work for you.
Good Luck
luciana44
Apr 10, 2010 | Brother DCP 130C All-In-One InkJet Printer
Word/Excel/Notepad docs will not print in black ink, will print in all other colors (incl those that require black ink) and everything else not Office product will print in black--new problem
Hi katethecat,
It is the Setup in your software.
First of all check this:
Go to CONTOL PANEL-> Printers-> select your printer if there are more than one listed.
Right Click on the name of the printer
Left click for the following:
Printing Preferences-.> color
Make sure the Color is selected and not the black or grayscale.
Click Ok
Exit from the menu
When you choose the color option it prints color & black
If you choose the black option, it prints everything in black.
Some software overrides it.
Please go into Word, Excel, Notepad etc and check the Printer Preferences are set to color not black.
Please give a rating.
Cheers
luciana44
Sep 08, 2009 | Microsoft Windows XP Home Edition
My printer is printing everything black when using feedtray only
Their should be a Black Copy button and a Color Copy  Button . When wanting to copy a document in color you must choose the color start button.. Good Luck
May 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
Won't print in color
All cartridges are new...report shows 0 pages for yellow left yet all others added at the same time show thousands of pages left. Everything printed is in black with no color. BTW: I have 3,000 pages left with black cartridge and the display says I need black.
What should I do?
Nov 20, 2008 | HP LaserJet 2840 All-In-One Printer
Epson 880 not printing in color
Found the answer. For some reason, my computer accepted a Mac driver. It called the printer Epson Stylus COLOR 880 (M). I went back to the original installation disk; thereafter, I had two printers, one without M, one with M, and deleted the M printer. All is working fine now.
Aug 09, 2008 | Epson Stylus 880 InkJet Color Printer
My brother fax machine is indicating that two color cartridges are almost empty, however i never print anything and color, and basically everything is black. so how can they be almost empty?
Three reasons -
If your print driver is set to color. It will use all the colors to make black.
Because the machine is ink jet it needs to clean the print head to stop it from drying out. It will use color ink to flush the print head every two days.
When ever in receives a fax it will use some color when printing a fax, particularly Cyan.
If you only wish to print or receive faxes in black there is now a version of Brother fax that only uses black ink and has no color inks. However it may not be available in your region. If you try and cheat the system you will only kill your print head.
May 02, 2008 | Office Equipment & Supplies
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
I want to print in black & white
After pressing Print, their will be a preferences button, click that and on the first tab should be an option to print with grey scale.
Oct 26, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP DeskJet 932c InkJet Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
