I have a whirlpool top load washing machine model no. 6ALSQ8000JQ2. it is about 7 years old and does not have an area that collects the lint in the machine. Previously this was not a problem, but in the last several months i have been getting lint and fluff on clothes that i have had in the machine. I began disolving powder in hot water and also put small loads with large water, thinking that i had posibly overloaded the machine. None of these attempts worked and i still have lint and fluff on my clothes. My work uniforms are dark coloured and i have had to replace them due to this problem! Please help if at all possible. (I am even trying a load of water with vinegar in it and no clothes to try to flush the pipes etc, to see if this helps)
  • Washing Mach... Master
  • 3,361 Answers
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER.
You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
Posted on Oct 06, 2009
Where is the lint trap and how do i clean it?
If the model number is true in the blue this a top load washer there is no lint trap lint collects on the protrusions on the outer side of the basket and is washed away during the rinse drain spin cycle
Aug 28, 2014 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
Hello. I think this is the model..it looks
Well Bridie no there is no lint filter inside your washer the only possible explanation, is either old lint and particles are coming from previous washes. or you have just washed something recently that may have come apart such as a pillow, a mat with a rubber backing, or even a blanket with any sort of fiber material in it. It is more than likely that much of the lint that goes through your machine is unseen and can cause pump issues. hope this helps.
Thanks
Oct 12, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool Cabrio top loading washing machine: approx. 12 months old: error F1, with every load. How do I get a new machine or this one repaired???? I'd perfer a new machine - different model. Help!!!!!
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Jun 07, 2009 | Whirlpool Washing Machines
Lint filter
I don't belive so after looking at all the parts lists it does not seem to have that feature
Feb 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Dec 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Apr 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
