Question about Avanti Kitchen Ranges
The broiler works and burners work but will not bake
  • 120 Answers
Chances are your bake element is dead. Find replacement part and remove and install as per directions.
Posted on Oct 06, 2009
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Broiler and top stove burners work, but oven doesnt
Your glowbar ignitor for the bake burner is bad.
Use the attached diagram to show location.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221257
Dec 26, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
Gas broiler and bake over do not work, top burners work.
Could be a board problem or the safety valve. Hard to diagnosis without being there. I'm leaning towards the board if both both burners won't light...hope this helps...
Nov 30, 2009 | Kitchen Ranges
My stove will not heat using bake but will work for broiler so I know it is not a heating problem. Help!
this model is not a dual fuel, and you do have a heating problem, there are two burners, a bake burner and a broil burner, both have ignitors. You have a bad bake ignitor.
Sep 27, 2009 | Maytag MGR5775QDS Dual Fuel (Electric and...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
I can't bake. The bottom burner in my stove is not working. The broiler works fine. Could the burner be bad?
yeah, it's definitely the burner. most people use bake more than broil and that's the reason why bake goes out first, almost all the time. you can check by getting a reading of 240v where the element connects to, assuming this is electric. If it's gas, then the ignitor needs to be changed and you should get 120v reading. Good luck.
Jul 08, 2009 | Kenmore Ovens
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Kitchen Ranges Logo
301 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
