Question about HP OfficeJet t45 All-In-One InkJet Printer
What info menu R0042 is?
The screen is not responding
You can try calibrating the stylus pen. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a game cartridge is not inserted in the Leapster2
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
5) Using the stylus pen, touch each of the crosshairs that appear
6) Restart unit
Feb 01, 2011 | Leapster 2
When you press the screen it dosen't work. Batterys are in a good place i don't know what to do is a brand new toy
6) Restart unit
Jan 25, 2011 | Toys
The styler or pen or whatever you call it is not working. We press on the screen and nothing. What does that mean?
Maybe you need to calibrate it. Calibrating the Leapster2 is easy:
6) Restart unit
Source: http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=1736&p_created=1221582020&p_sid=DqRj3Kxk&p_accessibility=0&p_redirect=&p_lva=1725&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MjkxMyZwX2NhdHM9JnBfcHY9MS4yOTEzJnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9Y2FsaWJyYXRl&p_li=&p_topview=1
Jan 22, 2011 | Leapster 2 Handheld Game
The stylus pen does not work
6) Restart unit
Jan 20, 2011 | LeapFrog Enterprises Leapster2 Learning...
My leapster 2 won't let me write my name in the screen?
6) Restart unit
Jan 15, 2011 | LeapFrog Leapster 2 Learning System
The touch screen ain't working
Try to calibarte it:
6) Restart unit
Source:
Dec 26, 2010 | Leapster 2 Handheld Game
I can not type in names to activate this toy. I touch the screen and nothing happens.
I think you need to calibrate this toys:
6) Restart unit
Dec 24, 2010 | Leapster 2 Handheld Game
I forget my privacy code
Well the easiest way is:
1: press menu and jump to enter emergency call
2: press and hold down menu button and while holding menu down,
press jump and back simultanously.you should enter the jump screen.
the end.
After u do that, if u wanna use the phone your gonna have to erase all the settings and do a master reset. Your going to need a tmobile sim card, and sidekick log in info to use the phone, which you should be able to get the login info by calling a T-Mobile CS agent.
Heres how u erase the flash and login info:
This is for the sidekick 2. It MAY work.
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
Good luck, hope that helped!
Jun 22, 2009 | T-Mobile Sidekick® 3 Cellular Phone
How do you get into the service menu on Samsung hcp4752w
I dont remember it exactly but ..if your TV is on then Press Standby and then press Info + Enter + Menu + Standby to turn on..you will get the service menu on screen.
Just alter the sequence of info + enter + menu to info + menu + enter or something.
hope it works
regards
bhavin
Apr 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
HP OfficeJet t45 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
