Question about Stokke Baby Gear
The handle does not stop at one point and moves up and down like in free wheel
Have ordered a new handle
Posted on Oct 07, 2009
  • Tanya Naomi Basten
    Tanya Naomi Basten Jun 10, 2016
    Mine is doing the same thing did replacing the handle rectify it x
Stopped going when free wheel lever accidently pushed forward. Put back. Still wont start.
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
Floor surface selector
A part of the front wheel carriage has been moved past it's stopping point by getting it caught under some object and forcing the handle down. Can't tell without examination whether or not the carriage is damaged or not, but it's a possibility.
Jan 05, 2012 | Bissell 3522 PowerForce Bagged Upright...
Attempted to update a single level "diamond" ball shower handle for an older Delta 600 series. Everthing seemed to go well, but when I turned the water supply back on, and when the handle was pointed...
On a single lever shower handle, when the handle is pointing straight down the water is off. The handle will then rotate 270 degrees to the right through cold - warm - hot. What has happened is when you took the other handle off the new handle didn't go into the same position as the old one. So now when the handle stops at the down position the valve is still open probable running cold water. The fix is to take the handle back off. Rotate the valve into the off position so that water stops flowing and reinstall the handle pointing down. Now when you rotate the handle to the right you will get cold then warm then hot at 270 degrees and back to off when the handle is pointing back straight down. If you are still having problems please let me know and we will examine it a little closer.
Jul 18, 2010 | Delta Home
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Hello. I have a 2000 Kia Sportage with a locked steering wheel. I pulled into my garage with the 4 wheel drive engaged due to the snow in the driveway. I shifted out of 4 wheel drive, but it will not...
try rocking the wheel to free off the key may be hard but is should release.as far as the 4wd is concerned it swithes off automatically when stopped/driving over 21 mph
Feb 17, 2010 | 2001 Kia Sportage
Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Oct 12, 2009 | Pride Celebrity X 3-Wheel Electric Scooter...
Which positions of the handle divert waater
The 'stop' is opposite the direction the handle extension points, so in the picture shown with this post the port pointing left is closed and the ports facing down and right are open.
Jul 31, 2009 | Pentair 2" Pvc, 3 Way Lube Free Diverter...
My Revo scooter will not move.It's like it's froze.The battery is charged. I turn it on and sounds like it wants to go but won't.
Sounds like the brake froze up on you.  It's the part that is attached to the motor with a handle on it to switch free-wheel and drive mode.  Try spraying some WD-40 into it and flip the handle up and down a few times then give it a go.
Apr 07, 2009 | Pride Value Line Revo Scooter 3 Wheel
Baby Gear Logo
213 people viewed this question
Top Stokke Baby Gear Experts
Dorel UK
Dorel UK
ray gallant
Are you a Stokke Baby Gear Expert? Answer questions, earn points and help others
