Question about Philips 190S5FB (Black) 19 in. Flat Panel LCD Monitor
Double image on Philips 190S monitor
My Philips 190S monitor has developed double vision, with everything on screen repeated as a shadow offset about 2mm to the right. Auto adjust fixed it for a while, but it came back. Do I need a new monitor, or is there a workaround?
  • gleighm Oct 06, 2009
    I have no argument with ZTLimited, but would welcome a second opinion.
    Thanks, guys. At least I have something to work on.
  • 313 Answers
Hi, May name is Randy, I have a few options for you.
You only have a few chooses:
  1. Download the update for your driver from this link: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=190S5FB/27B&slg=en&scy=US
  2. Try un-installing and re-installing the driver with the update
  3. If you monitor is under warrenty ( I am assuming that it isn't buy the model number) have it serviced.
  4. Buy a new one, they are about $150.00 now (if you were happy with it before this happened)
If you know how to us an ohm meter and you are comfortable with soldering gun, you could buy a sevice manual for it. But I would not suggest it. You usualy end up buying a new one anyway.
Thank you for the chance to help.
Try to update the driver, if it doesn't work Go shopping!!
Randy
FixYa Support Team
If this helped you in any way let me know, Rate me.
Posted on Oct 06, 2009
  • 17,970 Answers
If you adjust the screen before, and the problem is back again, this is the convergence circuit gone bad. a repairman is needed for this fix, is not necesary change the monitor.
Review this tips: Philips Convergence
Before replacing make sure everything in service menu is at original values.
Istill had to fiddle with the manual convergence to get the colorsright. In the regular menu, disable auto perfect focus. It's worthless (Samsung).
I hope help you.
Dell flat screen monitor is repeating images
"Shadowing" effect fixed by separating the wires in back. Touching wires cause crosstalk of signals . Immediate fix.
Aug 01, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
Double vision screen
This is most certainly a display problem, as in, a problem with the LCD panel. I used to fix 4 or 5 LCD's a day and had a few with the same problem. It can be fixed by being replaced.
Jan 06, 2014 | Computers & Internet
The text and images appear as "double vision"
i had the same problem with my Dell computer and Samsung 931a monitor....after being on the phone with Dell for overe two hours and setting up a technician visit, i googled "computer monitor double image".....i went to Fixya and read several tips, but the one most often repeated worked immediately!....check and tighten your blue plug from your monitor to your computer!!
Jan 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
'Shadows' behind all texts and images on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Double Vision
can you move the cross if you can.t your have bad stk that gone bad.
Sep 09, 2009 | Televison & Video
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Double image
have you done convergence? and is there a auto focus?
Jan 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Double image or shadow image
We recently had the same problem with our church projector and we too had just changed the lamp. I read somewhere while searching for an answer that if the cable input is loose it will cause double vision of the text. Sure enough, the cable was loose and after tightening the text cleared up immediatly.
Dec 26, 2007 | Philips ProScreen 4750 Impact Multimedia...
Philips 190S5FB (Black) 19 in. Flat Panel LCD Monitor Logo
200 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
