Question about HP Color LaserJet 2600n Printer
I need to get new color toner. It indicates
I need to get new color toner. It indicates "order supplies" I just need to print in black and white and I just put in a new black cartridge the other day. Is there something I can do to a setting to still be able to print w/o full color toners?
  • 3 Answers
Go into your printer menu to your replace supplies section and turn on your override I did this and was able to print out about another 250 sheets
Posted on Nov 12, 2009
  • HP Expert
  • 222 Answers
You can't do anything except changing necessary color cartridge
Posted on Oct 06, 2009
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
Epson Workforce 600 not recognizing black toner
I had the same problem and was told by the store that sold it to me that some printer manufacturers do this on purpose as they make their most money on the ink they sell not the printer. I got rid of mine and purchased an ink jet black only printer as this is all I need anyway. A lot cheaper to use.
Jun 12, 2017 | Office Equipment & Supplies
White lines when printing
Usualy white lines are a signal for you that is time to replace a toner cartirdge.
Your machine may inform you that you need to replace a toner cartridge, but sometimes the toner levels are low and the machine doesn't indicate that.
Another thing that you may try is to clean all toner cartridges using each corona wire.
If you need to replace your toner cartridge check this easy and helpful way to replace toner cartridge.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I have only black toner, colors are out. How can I keep printing? It sends a message: "replace supplies".
You need a supply of ink in both cartridges in order to print. Even if you are only printing black ink and there is a black ink cartridge with ink in it, your printer will not print without the color catridge installed and it has to have a supply of ink in it. I wish I had better news for you, but unfortunately I don't.
Aug 17, 2011 | HP LaserJet 2840 Printer
How do you print only in black & white to a dell 5110cn laser printer? the printer is currently out of magenta toner and will not print. do you need a magenta toner cartridge in order to print to this...
go into printer and faxes and and right click on your printer and and go to printer Prefereces you should see either print in black in white or gray scale
this should fix it for you
Good Luck
Happy Computing
Jan 09, 2010 | Dell 5110cn Laser Printer
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
My Dell 3000CN is out of yellow toner
located in your control center for the dell printer is an option to print in black and white onlhy. click that u should be able to print.:)
Sep 07, 2009 | Dell 3000cn Color Laser Printer
Scanner won't pick up colored inks from paper, multiple sheet jam
This printer only prints black and white. Canon do not supply Multi-color toner catridges for Canon Imagerunner 1023N
Jan 10, 2018 | Canon imageRUNNER 1023N Black and White...
Printer won't print
Many printers will not print if one color is out, some will. One thing to check is to make sure that when you print, the option for "balck and white" is selected in the printing preferences.
Many people don't realize that even though the document may be black and white the printer still processes it as a color document which wastes costly supplies.
Nov 25, 2008 | Dell Office Equipment & Supplies
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
