Question about Alpine CDA-9883 CD Player
How to change amplifire? - Alpine CDA-9883 CD Player
  • 70 Answers
Amp is most likely an large IC mounted on a heat sink.Remove its mounting screws remove solder from the ic pins on circuit board ,install, mount, and solder in new IC ,install cover and unit should work if IC was only problem.Check for burn't parts,damaged circuit board copper runs.
Posted on Oct 06, 2009
The plug on the Panasonic SL-700-- Turntable..does it plug into a Amplifire or straight into the wall..
This doesn't make sense. The RCA plugs are inserted into an amplifier; the AC cord plugs into the wall. Any other arrangement will lead to trouble
Sep 28, 2012 | Panasonic Audio Players & Recorders
How to splice factory speaker wires on 2004 grand am with monsoon
everything depence of system you putting in your car if u have no amplifire you connecting the speakers to radio as they marked i you putting one in, your speakers wires goes from amplifire to speakers there is no diffrent way of connection. also the diameter of your wires have to be adekwate to power u going to have in your system for optimizing the sound quality let me know if this help ya
Sep 22, 2012 | 2004 Pontiac Grand Am
Panasonic sbwa350
The subwoofer for that system also powers the rest of the speakers as well as the
subwoofer as you probably know. Is there any power light coming on? Like on the subwoofer itself where ever the power light is. If not check for a fuse. If no fuse is visable you'll have to take the subwoofer apart, the plate amplifire. There will be screws all around the metal part on the back, you must remove all the screws holding it together. Most of these types of systems have the fuse inside on the board. Also sometimes the fuse does'nt look like a fuse, it could look like a resistor or a ceramic style disk capacitor. Yours will probably have a glass type fuse. If you don't see one look on the board next to the components on the power supply board or if all together look near the transformer area for a F meaning a fuse. /there will be letters and numbers next to each component eg., resistor, capacitor, diode, etc. If you find a glass type fuse replace it with the exact same rating which will be on the end of the fuse on the silver ends of the fuse. If it's not blown you'll need to test to see if your getting voltge out of the transformer. You'll have to have the DVD unit hooked up to it, you don't have to have any speakers connected. The cable from the DVD unit to the subwoofer is what tells the amplifire on the subwoofer to turn on. You could have a blown amplifire IC. I don't know what type of ouput amplifires this uses but I'm thinking IC and not seperate transistors for the output amplifires. You might have one of those blown and if you do then the whole system wont work. Hopefully if that is the problem you'll see a burnt mark on the IIC itsel or some type of burnt spot on the board somewhere to lead you in the right direction to the problem. It could be as simple as a power supply capacitor, who knows til you get into it and start looking around and testing some things. If you don't have the knowledge to do this I am the cheapest electronics business in the USA. It's not a bad system, CrutchField sales it. Also I can waalk you through the steps to narrow the problem down. I help people everyday. You can contact me at ampman37@gmail.com. I can then give you some more info and my business phone number if you feel up to doing this. It's really no big deal and I find that most of my customers who have never done something like this love and learn some electronics and now fix some other stuff they had laying around. I'm here to help. Thank you for contacting me, have a good day.
Jan 06, 2012 | Panasonic SB-WA100 Subwoofer
Line six guitar amplifire...controls
Hi! I have a Spider III 15 watter, but I think the functions are similar. If the "Tap Tempo" light is flashing, you are not in Reverb mode. The light must be lit steady if you are in "Reverb" mode. I notice that you have to rotate the knob that you're working with all the way counterclockwise, and then clockwise to the setting you're trying to get. If you just turn it clockwise from where it is when you power on, it doesn't seem to do much to change the settings. Also, very little movement of the knobs makes a big change. They seem to be very sensitive.
You may want to reset your amp to the factory default settings. This will clear ALL presets that you have saved! To do this, hold down the CLEAN channel button when you power it on. Again, ALL SAVED PRESETS WILL BE CLEARED! Hope this helps.
The Line 6 forums are a great place for info. They will even tell you about "Secret Settings" that are not in the manual. Good luck and rock on!
Oct 03, 2009 | Audio Players & Recorders
Radio
well caddys have (most likely) has a low grade HIGHEND name "entertainment" system...a.k.a BOISE , JBL etc. it wont mess anything up I dont think..BUT it wont work...you need to speak with a INSTALLER and get the right wireing harness chang over...My LINCON M8 has a JBL and we just ran new speaker wire and by passed the stock cross over and amplifire ....but you cant just hook it up and have it work..
May 10, 2009 | Car Audio & Video
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
How connect amplifire ??
You hook the amp up to the deck with rca cables red and white. you have output rca on the back of the deck also the blue wire labled remote also goes to the amp to turn it on and off.
Jul 19, 2008 | Blaupunkt London MP37 CD Player
Panasonic TX-34P300X Audio problem
I have facing some problem model Tx-34P300X panasonic Tv UK Model for sound not coming .But Amplifire is Ok. Pre not working.
Jan 17, 2008 | Televison & Video
Sir i have seriouse Problem
I can't find any information on that model. My suggestion is to hook it up and see how it preforms. You will know right away if you were lied to. Please remember to leave good feedback.
Oct 03, 2007 | Solid Audio Formula Series F27 2-Channel...
Alpine CDA-9883 CD Player Logo
62 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
