Question about StarTech.com StarView SV211K 2-port KVM Switch
C&w codes gone again can anyone help pls?
Nothing is showing
  • 15 Answers
C & W 5C 01] 06/10/09
00 = BC B6 BB DD 97 AD 11 63
01 = 42 B7 84 3E BE 8C 4E 65
Telewest 5A01 06/10/09
00 = C2 B5 BE 41 0D 9B C5 7C
01 = 6D EA 8E 97 6A AA DA 71
NTL 54 01] 06/10/09
00 =A0-51-3B-27-17-7D-D0-28
01 = F0 CF C3 01 F1 2D AB B8
try one of these bad boy good luck
Posted on Oct 06, 2009
I have a 2002 galant and error codes p0335 & p0340 keep coming up. I changed the sensors and had autozone erase the codes but after I turned engine off and started again the codes came back up! Has...
some vehicles set these codes when ignition is turned on but engine not running,
but then goto a not pressent code(history code) or no code present, when engine is running. This may be the way the system works, which with genuine scanner it may
show this but with some aftermarket scanners may only show that the code sets,
not what its status is or if its gone, it remains displayed.
So you could clear codes, engine not running, cycle ignition and if code comes back again without starting engine this is normal for this system (NO FAULT).
If it only sets again when engine has run,
is cam timming correct?
teeth on reluctor wheel all o.k. bent or dammaged?
or debris stuck to reluctor wheel?
Earth circuit could be shared with both sensors is it ok? -repair wiring or bad earth.
low Ohms reading test from sensor connector.
Is power to sensor circuit uninterupted & ok? -repair wiring
Oct 01, 2011 | 2002 Mitsubishi Galant
Euro vox max gone off
Unfortuntely the code above does not work as it was changed again. Anyone got a new code for NTL in Luton?
Feb 09, 2010 | Televison & Video
Kenmore Elite dishwasher: not doing anything.
turn off power an back on / if no change remove the toe panel and the tech sheet will be there . it will tell you what the code is and how to correct most .. mm hope this helped. pls leav feed back.
Dec 07, 2009 | Dryers
Lost installation code for command & conquer
HKM5-YD73-72H6-B273-6FLT THERE YOU GO AND DONT FORGET TO RATE :)
Mar 22, 2009 | EA - Electronic Arts Command & Conquer 3:...
Need todays new codes for Telewest
does anyone have the codes for chorus mmds some channels gone
Mar 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
My digivox is scrambling all my channels. Was working fine for about 6 months, then all of a sudden all channels gone. tried entering 0000 again. But nothing!!!! Can anyone help
are ur fta channels still working if they are then ur cable co. has changed codes you'll need to put new codes in or download new software to fix this problem hope that helps.
Jan 02, 2009 | Computers & Internet
Mercedes a class gearbox fault.no gears
Its a part inside the gearbox called the k1 clutch assembly, that has gone faulty. Unfortunately no quick fix.
Apr 30, 2017 | 2003 Mercedes-Benz C-Class
My monitor works fine for 0.5 sec every time I turn on my PC and then nothing
sound like the monitor is gone.
if it is still in Warranty, you can call Samsung.
if it is out of warranty, take it to any computer repair shop. (cost may be prohibitive.)
the last option is get a mew one.
Nov 10, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
StarTech.com StarView SV211K 2-port KVM Switch Logo
88 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
