Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Frost buildup inside freezer door at ice dispenser
Six year old GE Profile side-by-side refrigerater. Frost continues to build up inside freezer door at ice dispenser. Warped "flapper door" was replaced a couple of years ago to correct the same situation. Although I can hear that flap close after ice is dispensed, might it still not be sealing? Or is there another likely problem?
  • 534 Answers
You are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Posted on Oct 06, 2009
I have a GE Profile Arctica refrigerator that I purchased used last week. Developing quite a bit of frost buildup inside the upper half of the freezer. Also noticing that the flap for the ice doesn't...
Hi yes the flap will cause the frost, you need to replace the solenoid that controls that flap, if this is a side by side, the solenoid is behind the dispenser controls on the freezer door, you take off the control board, and then remove the little mount behind that it has 4 screws and you will see solenoid on right side, it needs to be replaced.
Sean
Mar 17, 2011 | GE Profile Arctica Stainless Steel Top...
3 1/2 year old whirlpool side by side has frost and ice building up inside the freezer compartment close to the door. Freezer seems to run continuously also...help?
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck
  6. 911servicetoday.com
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup on area where ice comes out of the ice bin with frost also on the inside of door chute
The flap door where ice is dispensed is warped letting warm air into the freezer causing the frost build up. You must replace the flapper - a $5 - $7 part but not too difficult to replace. I find the flapper last only about 2 years and frost problem reappears. Forget about a "weak heater".
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 | Freezers
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Refrigerators Logo
1,262 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
